rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Update - February 7. - Picked up a "New" sled. 2006 Apex With custom turbo system. And a few pics from my real job
I got the sled from a good friend of mine, he's the one that caused the turbo garage to come into existence.
The sled need a lot of work, I'm going to build it from the ground up.
My hope is to make around 400 HP when the sled is done.
It's going to be an interesting Project, thanks buddy.
I got the sled in parts and pieces, which is great, then I can rebuild it from the ground up.
When not working on turbo sleds I make a living running the computer systems for the local government at the county hall downtown. Installing more Storage.
I need a few parts before I can rebuild the sled.
The sled encountered a cross pin failure at the #4 piston.
The Wiseco 2006 cross pin failed causing damage to the piston, Carrillo rod and all 5 valves, it also caused damage to the cylinder and Block. I'm thinking of getting hold of a used engine or a New cylinder Block.
Anyone having one laying around?
More to come.
More to come.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
No I have not ridden the sled yet.
The owner is getting the break in miles done, then we will do the test and see what it does.
I don't know when.
I don't know when.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Update - April 14. - Tuning a few Apexes.
It's been a slow season in rxrider's Turbo Garage.
At last a few late season tuning sessions came in.
A few guys wanted to get a little more out of their sleds the last few weeks of the season.
This sled was in to adjust boost pressure.
The sled was Down on boost, only 10 lbs.
I adjusted up the pressure in the MCX ECU boost map and took the sled for a spin.
No change in boost pressure.
I smelled gasoline when giving it wot???
I checked all the fuel lines and hose clamps, all checked up Perfect.
We figured what it was, the fuel rail had jumped off the engine slightly leaking boost pressure.
The intercooler came off and then the fuel rail. Reinstalled everything and the boost leak and smell gasoline was gone.
Adjusting boost pressure up slightly is NeXT.
The NeXT sled was in for a fuel system Upgrade. It's a Apex With MCX260 we're upgrading to MCX290.
The Stock fuel pump is not up to the task and has to be removed.
A New high capacity fuel pump is going in to feed the engine the fuel it needs at 290 HP.
The fuel pump installed.
The Stock fuel pump has been removed.
It's replaced by an adapter.
The Stock fuel pickup is removed from the Stock fuel pump Assembly and installed on the fuel pickup adaptor.
The old Stock fuel pump has been removed.
The sled has the MCX Gen2 ECU, it's possible to install the MCX Display unit to it but it's a lot of work.
Instead we installed a Hallman Pro RX manual boost Controller to raise the boost to 14 lbs or 1.1 bar.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Motor just posted in classifieds in NY which is closer for shipping to Norway. Seller is henseljg2
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Thanks kinger I need one Apex Block and cylinders and one for the RX-1.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
THREAD INDEX SEASON 2007/2008:
Page 1 - http://www.ty4stroke.com/threads/rx...-viper-mcx270-turbo-install-done.47473/page-1
- Battery and front end bushing install.
- Installing the front end and Fox Float Air Shocks.
- Finishing off battery relocation, installing fuel pump and fuel pressure regulator.
- Carb tuning, changing pilot jets.
- Chaincase removal, primary clutch tuning and cleaning.
Page 2 - http://www.ty4stroke.com/threads/rx...-viper-mcx270-turbo-install-done.47473/page-2
- Installing the SuperTips clutch weights, more cleaning of the primary clutch.
- ZX-2 136" assembly.
- Removing the ProAction, preparing for the ZX-2 install.
Page 3 - http://www.ty4stroke.com/threads/rx...-viper-mcx270-turbo-install-done.47473/page-3
- Installing the ZX-2 mounting kit into the tunnel.
- Fixing up a leaky floor board heat exchanger.
- Modifying my rear heat exchanger to fit the 136 MPI tunnel extension.
Page 4 - http://www.ty4stroke.com/threads/rx...-viper-mcx270-turbo-install-done.47473/page-4
- Welding up the cracked left side heat exchanger.
- Installing the modified rear heat exchanger.
- Checked the turbo and piping.
- Reinstalled the seat and finished off the rear end.
- Track inspection and stud maintenance.
- Installing the drive shaft and chaincase.
- Installing the ZX-2.
- Changing the engine oil and oil filter.
Page 5 - http://www.ty4stroke.com/threads/rx...-viper-mcx270-turbo-install-done.47473/page-5
- Installing the carb rack, intercooler and piping.
- Replacing the left hand side jackshaft bearing.
- Innovate WBO2 free air calibration.
- Adjusting oil and coolant level.
Page 6 - http://www.ty4stroke.com/threads/rx...-viper-mcx270-turbo-install-done.47473/page-6
- Morgan CarbTune Pro preparetion.
- Carburetor syncronization.
Page 7 - http://www.ty4stroke.com/threads/rx...-viper-mcx270-turbo-install-done.47473/page-7
- Turbo testride 2, a ZX-2 review.
- Replacing broken HI/LO headlight switch.
- Adjusting Fox Floats.
- Adjusting pilot screws and idle AFRs
- Testing suspension front and rear.
Page 8 - http://www.ty4stroke.com/threads/rx...-viper-mcx270-turbo-install-done.47473/page-8
- Testing idle AFR.
- Checking ZX-2 suspension bolt torque.
- Adjusting limiter strap ZX-2 136"
- Testriding with limiter strap in middle position ZX-2 136"
- Jetting, changing needle clip position.
- Adjusting track tension.
- Checking ZX-2 bolt torque.
- Adjusting ZX-2.
- Carburetor work - changing main jets and adjusting pilot screws.
- Installing tunnel protectors over the rear cooler.
Page 9 - http://www.ty4stroke.com/threads/rx...-viper-mcx270-turbo-install-done.47473/page-9
- Repairing the charge tube.
Page 10 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-10
- Changing gears in the chaincase.
- Swapping out carb springs.
- Adjusting belt ride height aka belt deflection.
- Fixing a boost leak in the rubber charge tube beween turbo and pre-cooler.
- Installing Apex Mountain skis.
- Adjusting primary clutch.
- Adjusting drive belt ride height aka belt deflection.
- Adjusting off-set.
- Checking chaincase oil.
- Adjusting chain tension.
- Apex Mountain ski review.
- Fixing loose exhaust clamp.
- Adding slider material to the tunnel protectors.
Page 11 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-11
- Installing second BOV.
- Adjusting track.
- Adjusting revolver settings.
- Playing with sorce for pressurizing the float bowls.
- Clutching and "Stock carb spring mod" for MCXpress turbos.
- Testride stock carb spring mod. Clutching changes.
- Removing left running board heat exchanger.
- Removing all studs from track.
- Installing heat exchangers.
- Installing a new track.
- Installing new '07 seat.
END OF INDEX
- Testing idle AFR.
- Adjusting ZX-2.
- Adjusting track.
END OF INDEX
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
THREAD INDEX SEASON 2008/2009:
Page 12 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-12
- Snow is gone and the upgrading of my TReX continues.
Page 13 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-13
- Nothing but smalltalk.
Page 14 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-14
- Painting the A-arms
- Turbo parts ordered
Page 15 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-15
- Painting of A-arms is done. Teardown has started.
- Turbo header and double downpipe arrived this morning.
Page 16 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-16
- Tear down nearly finished.
- Chaincase and drive shaft removal.
- Changing loose rivets.
- Fitting the turbo header into the RX-1. Removing A-arms.
Page 17 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-17
- Servicing and maintaining the steering.
- R&D work - fitting a Yamaha Apex seat on top of a REV gas tank.
Page 18 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-18
- Painting front end parts.
- Draining oil and changing oil filter.
- Installing ball joints and steering components.
- Installing Wildchild steering relocation kit.
- Installing A-arms and steering components.
- Fitting Yamaha seat bottom, REV gas tank, Side panels and Tank covling.
- Fitting the turbo header, a mockup (testing) install.
Page 19 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-19
- Installing outside arms to king bolt (ski assy column) and tie rod ends.
- Working on it
- Seat development continued.
Page 20 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-20
- Installing heat shield, cover plate stock exhaust holes, sealing up the tunnel.
- Installing header, Top heat shield, WildChild steering relocation kit.
- Working on the tank covling.
Page 21 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-21
- Miscellaneous
Page 22 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-22
- Installing parts on the REV gas tank.
- Re-routing handlebar wireing. A soldering project.
Page 23 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-23
- Removal of carburetor rack.
- Carburetor cleaning.
- Assembly of the carburetor rack.
- Removing weight.
- More wireing and soldering.
Page 24 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-24
- Finishing off carb rack assembly.
- Installing turbo carb springs from HURRICANE.
- Adjusting ski alignment.
- Installing fuel line and fuel return line.
- Finishing off the handle bar wireing project.
- Installing skid plate and then some.
- Building new tubing for the pressure/vacuum signal hoses.
- Re-packing secondary side jackshaft bearing with new grease.
- Routing fuel and vent lines for the REV gas tank.
- Re-packing speedo side driveshaft bearing with new grease.
Page 25 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-25
- Building new plumbing from the carb boots to Boost Meter, Vortech Race Bypass, Mitsubishi BOV and Malpassi Fuel Pressure Regulator.
- Adapting the hood and tank covling to the Wildchild steering post.
Page 26 http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-26
- Removing MCXpress turbo kit parts.
- Installing the RX-1 fuel meter pickup to the REV gas tank and plugging the original tank vent.
- Relocating the dash piece.
- Working on the the dashboard relocation bracket.
- Installing my Innovate LC-1 and XD-16 WBO2 system, re-wired to fit my front mount turbo system.
- Cleaning up black plastic parts.
- Painting the speedo gauge relocation bracket.
- Installing hood mounting brackets.
- Installing gauge pod, connecting wireing.
Page 27 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-27
- My MCXpress RX-1 Turbo kit is up for sale.
- Unpacking Powder Lites RX-1 Turbo parts.
Page 28 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-28
- Mock up install of the header, turbo, downpipe and heat shields.
- Installing magneto washer and bolt, mogneto cover and gasket, oil tank and hoses.
- Installing cover plate for the old exhaust outlet.
- Making a cover plate for the new exhaust downpipe.
- Installing plate to cover up the tunnel.
- Installing water cooling tubes to the turbo.
- Installing plate where the rear bulkhead frame piece used to be.
- Fuel tank is done, preparing for install.
- Turbo and downpipe mockup install.
Page 29 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-29
- Cutting the hood to fit with the header and turbo.
- Cutting the wind screen to fit with the handle bars.
- Installing the turbo heat shields.
Page 30 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-30
- Making a card board template for a new turbo heat shield. Cutting aluminum sheet metal.
- Fitting the Powder Lites heat shield, part 2.
- Hammering the new turbo heat shield into shape.
- Last adjustments to the heat shields.
- Driling out bolt holes for installing of the Powder Lites heat shield and the new heat shield.
- Mockup install of turbo, downpipe and heat shields.
Page 31 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-31
- Installing track clips.
- Preparing for track install.
- Looking over the drive shaft.
- Changing brake pads.
- Preview of Powder Lites Stage 3 Intercooler.
- Installing new PL silicone hoses to the carb rack.
- Removing MCX oil filter adaptor.
- Relocating fuel pressure regulator and Innovate LC-1 to make room for the Vortech Race Bypass valve.
Page 32 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-32
- Installing oil adaptor plate, oil filter and oil feed line for turbo.
- Installing oil return line. Intercooler test install.
- Installing new 45 degree oil drain pipe for the oil return.
- Installing turbo and hooking up oil return line to the turbo.
- Installing water lines and adding heat shielding material.
- Insulating oil and water lines at the turbo.
- Installing WBO2 sensor and insulating the wireing.
- Installing downpipe.
- Installing turbo heatshields.
- Installing new connections for Innovate XD-16 wireing.
Page 33 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-33
- Installing Innovate XD-16 and wireing.
- Installing boost meter.
- Installing Powder Lites Stage 3 Intercooler.
- Installing Vortech Bypass Valve.
- Plumbing pressure/vacuum lines.
- Checking my ZX-2 skid for wear.
- Installing water cooling lines to the turbo.
- Fabricating a heat shield to go behind the secondary clutch.
- Adding more heat shielding near the turbo and header.
- Adding engine oil.
- Installing track, driveshaft and chaincase.
- Installing brakes.
Page 34 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-34
- Adding heat shielding materials to the fuel tank.
- Installing the REV fuel tank.
Page 35 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-35
- Bolting down the REV fuel tank.
- Installing Hallman Pro RX manual boost controller.
- Installing heatshield, secondary clutch and side covers.
- Installing charge tube between turbo and intercooler.
- Installing air filter, silicon hoses and aluminum tubing - part 1.
- Installing air filter, silicon hoses and aluminum tubing - part 2.
- Installing air filter, silicon hoses and aluminum tubing - part 3.
- Sealing off the headlight pod after cutting into it.
- Cutting out a hole in the hood for the air filter - part 1.
- Cutting out a hole in the hood for the air filter - part 2.
Page 36 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-36
- Molding a fibreglass bottom for the seat.
- Cutting the fibreglass bottom to fit.
- Cutting out the seat to fit onto the Rev gas tank.
- Cutting out the seat to fit onto the Rev gas tank - part 2.
- Fabricating mounting brackets for the REV gas tank.
- Preparing the seat and seat bottom to be joined.
Page 37 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-37
- Fabricating rear seat mounting brackets.
- Fabricating the front seat mounts.
- Adding more wents in the plastics behind the engine and turbo.
- Preparing the seat and seat bottom to be joined together.
- Joining together my custom Apex seat and the fibreglass seat bottom.
- Installing seat and tank covling.
- Free air calibration of the WBO2.
- Fire in the hole, it's alive.
- Checking oil level.
- Working on it
- Miscellaneous
- Removing weight.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Page 38 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-38
- Syncronizing carburetors.
- Grinding off tank covling to fit over the turbo heat shield.
- Insulating tank covling and hood using heat reflective tape.
- Installing the last screw holding the windscreen in place.
- Running the engine to check for leaks and listen to the awesome sound it has
- Adding more heat shielding materials to the tank covling and turbo heat shields.
- BUILD IS DONE - TUNING REMAINS
- First ride. Checking boost and AFR levels. WOW it has some throttle response now
Page 39 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-39
- Powder Lites powered Attak converted from a MCX rear mount to a Powder Lites front mount.
- Second ride. Checking for leaks. Checking heat shields.
Page 40 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-40
- Third ride. Checking for leaks, heat shields, boost pressure and AFRs.
- Fabricating an oil restrictor to reduce oil pressure to the turbo.
Page 41 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-41
- Water-Meth kits, hardened head studs and MSD Launch Master has arrived.
Page 42 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-42
- Unpacking the Water-Meth kit, hardened head studs and MSD Launch Master.
- Removing cams.
- Installing ARP head studs.
- Installing ARP head studs, continued.
Page 43 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-43
- Installing Hurricane/Snow Performance Water-Meth Injection Kit. - Part 1.
- Installing Hurricane/Snow Performance Water-Meth Injection Kit. - Part 2.
- Installing Hurricane/Snow Performance Water-Meth Injection Kit. - Part 3.
- Installing Hurricane/Snow Performance Water-Meth Injection Kit. - Part 4.
- Reparing fuel leak in the fuel return line.
Page 44 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-44
- Installing meth injection failsafe solenoid.
Page 45 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-45
- Repairing leakage in the tank vent line.
- Rewireing of fuel pump, WBO2 and Meth Injection system to battery.
- Changing spark plugs and adjusting gap.
- Lowering carb needles.
END OF INDEX
- Removing cams.
END OF INDEX
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
THREAD INDEX SEASON 2009/2010
Page 46 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-46
- Adjusting fuel pressure.
- Parts on order.
Page 47 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-47
- Tearing the sled apart - part 1.
- Tearing the sled apart - part 2.
Page 48 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-48
- Measuring valve clearance (or valve lash).
- Removing cam shafts.
- Removing cylinder head.
- Removing and documenting valve shims.
- Installing ARP 10 millimeter hardened head studs.
- Reinstalling intake cam shaft to check valve clearance.
- Preparing to check valve clearance.
- Checking valve clearance.
Page 49 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-49
- Adjusting valve clearance.
- Preparing for cam degreeing.
- Installing the cylinder head.
- Adjusting cams sprockets.
- Degreeing cams.
- Installing cams.
- Test installing the dial indicator for finding true TDC
- Test installing the Cam Timing Jig and dial indicators for measuring valve lift.
- Making a new degree wheel pointer.
- Fabricating a degree wheel conversion.
- Installing cam degreeing equipment.
- Initial measuring.... let's go to school
- Cam degreeing - Part 1.
Page 50 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-50
- Cam degreeing - Part 2.
- Cam degreeing - Part 3.
- Installing cylinder head cover.
- Installing plugs, coils and piping.
- Installing delta box frame.
Page 51 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-51
- Greasing up jack- and driveshaft bearings.
- Installing fuel pump and bracket.
- Installing oil tank and hoses.
- Installing coolant tank and hoses.
- Installing aluminum mounting blocks and oillite bushing for the steering shaft.
- Installing electrical wireing.
- Installing carbs.
- Routing electrical wireing.
- Installing relays for fuel pump and meth injection kit.
- Installing meth injection nozzles and meth lines.
- Installing vacuum/pressure lines.
- Routing fuel lines and preparing for auxilary fuel tank in the nose.
Page 52 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-52
- Installing meth injection Part 2.
- Preparing for water temp sensor and gauge install.
- Installing boost controller and meth failsafe bypass solenoid.
- Preparing for a different install of the meth reservoir.
- Installing water temp housing and sensor.
- Installing intercooler.
- Hooking up meth injection.
- Rerouting fuel- and fuel return lines.
- Preparing for new lines for cooling the turbo.
- Wrapping up the turbo header.
- Preparing header bolts.
- Installing header.
- Preparing and installing turbo.
- Connecting and insulating water lines to turbo.
- Adding oil to the turbo oil inlet to lube turbine bearings.
- Installing pressure lines to boost controller and meth injection fail safe solenoid.
- Installing and insulating oil line.
- Insulating and installing downpipe.
- Making a aluminum heat sink for the O2-sensor.
- Connecting coolant hose from the turbo to the thermostat housing.
- Adding heat shilding material to lines, hoses and turbo.
- Installing O2 sensor.
- Installing turbo blanket.
Page 53 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-53
- Working on the aluminum heat shields for the turbo, header and downpipe.
- Working on the aluminum heat shields for the turbo, header and downpipe - part 2.
- Installing charge tube and Vortech Race Bypass Valve.
- Installing piping for air filter.
- Installing Water Temp Gauge into gauge pod.
- Adding coolant.
- Installing hose clamps and securing air filter and piping.
- Cleaning and installing clutches.
- Installing steering column, billet aluminum mounting blocks and oillite bushings.
- 08 Apex RTX 136" MCX440 turbo kit.
Page 54 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-54
- Finishing off steering column install.
- Finishing off meth injection install.
- Installing throttle and chocke cables.
- Hooking up electrical plugs and wireing.
- Cutting out the hood to make it fit. Testing ignition circuitry.
- Installing fuel tank.
- Insulating meth lines.
- Installing seat. Fireing up the engine.
- Syncronizing carbs.
- Changing out leaky oil line and finishing off wireing and plumbing under the hood.
- Adding more vents to the plastic covers.
- Installing plastics and covers.
- It's done, time to ride and tune.
Page 55 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-55
- Nothing really, guys chatting
Page 56 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-56
- Exhaust cut-off valve invented.
- Installing MCX315 on a 2008 Apex LTX.
- Installing water temp gauge.
- Installing restrictor on float bowl pressure signal line. Didn't work :-(
Page 57 - http://www.ty4stroke.com/viewtopic.php? ... &start=840
- Testriding my '03 RX-1 Turbo.
- More Web clutter LOL.
END OF INDEX
- Parts on order.
- Degreeing cams.
- Installing cams.
- Installing carbs.
- Adding coolant.
END OF INDEX
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
THREAD INDEX SEASON 2010-2011
Page 58 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-58
- Stretching my ZX-2 to 144". Unpacked the AD Boivin 144" extension kit.
Page 59 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-59
- MCX260 Turbo Install Guide 2006 version.
- MCX260 Turbo Install Guide 2007-2009 version.
- MCX290 Turbo Install Guide 2010 version.
- MCX Display Unit Install Guide.
- A sneak peak on a 50mm TiAL Q BOV.
- Extending my ZX-2 from 136" to 144".
- Removing chain case, drive shaft and the old track.
Page 60 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-60
- Nothing useful, just talk, talk, talk, have a beer...
Page 61 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-61
- Installing speedo side drive shaft bearing.
- Installing chain case and cover.
- Changing engine oil.
- Installing ZX-2 144" skid, done.
- Changing oil.
- Installing a new seat on my 08 Apex RTX.
- Repairing damaged wireing on my friends 06 Attak.
Page 62 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-62
- Repacking drive- and jackshaft bearings.
- Greasing front and rear suspension.
- Cleaning primary and secondary clutches.
- Installing TiAL Q BOV.
- Installing IC.
- Setting carburetor needle position.
- Project 06 Attak - custom turbo sled.
- Installing MSD Launch Master PN 4350.
- Adapting MCX Diplay Unit to 2007 MCX Controller Unit.
Page 63 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-63
- Ski-Doo XP1200 MCX180 turbo install.
- Yamaha FX Nytro MCX180 turbo install.
- Tuning MCX Computer on a 08 Apex LTX.
- Turbo Garage custom project sled coming to life.
- 2011 Apex MCX 290 Turbo Project.
Page 64 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-64
- 2008 Apex MCX 290 Water-Meth Install.
- 2006 Custom Attak, upgrading the turbo.
Page 65 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-65
- Upgrading Nytro MCX180 to MCX240.
END OF INDEX
- Changing oil.
- Installing IC.
END OF INDEX
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
THREAD INDEX SEASON 2011-2012
- Installing Carrillo connecting rods.
- Strenghtening Apex engine.
- Parts are in. Pics of the rods are posted.
Page 66 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-66
- Installing Ski-Doo 1200 MCX300.
- Installing Carrillo Rods and JE 10:1 Pistons in Apex MCX330.
END OF INDEX
END OF INDEX
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
THREAD INDEX SEASON 2012-2013
Page 67 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-67
Apex MCX260.
- Installing new headgasket and shim. Adjusting valve clearance.
Apex MCX290 Mid-Mount
- Removing the cam caps, shafts, buckets and valve shims.
- Cleaning the cylinder head and cylinders.
- Installing MCX head gasket/shim.
- Adjusting valve clearances.
- Installing cam shafts.
- Adjusting spark plug gap.
- Installing adaptor for oil feed line to turbo.
- Installing cylinder head cover, plugs, coils and coolant pipes.
- Installing exhaust heat shield.
- Cutting the frame to make room for the mid-mount turbo.
- Installing the precooler charge tube.
- Installing aluminum plate to cover up the hole where the stock exhaust muffler use to be.
- Installing silicone hose from Precooler to Intercooler.
- Installing MCX oil return pump.
- Installing Battery bracket, battery and the stock ECU.
- Installing crank vent hose.
- Modifying throttle spring tension.
- Installing throttle bodies.
- Installing oil tank.
- Strapping up air intake temp sensor.
- Installing MCX EFI Computer.
- Connecting the EFI wireing to the stock harness.
- Connecting pressure/vacuum lines.
- Installing silicone boots and hose clamps.
- Installing IC.
- Connecting EFI signal wire to injectors on the IC.
- Installing BOV and vacuum line.
Page 68 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-68
Apex MCX290 Mid-Mount - Updated.
- Installing aluminum bar across the tunnel.
- Installing exhaust pipes.
- Installing Turbo and connecting charge tube.
- Installing heat shield over turbo.
- Installing exhaust outlet pipe.
- Installing exhaust silencer.
- Installing heat shield for the airfilter.
- Installing Electronic Boost Controller.
- Installing air filter.
- Installing and routing oil feed line, vent line and oil return line to turbo.
- Added engine oil.
- Started up the engine, checked for sirculation.
- Installed new helix and secondary spring.
- Installed new primary spring and SuperTips 60Y-3 clutch weights.
- Installed the clutches.
- Modifying seat.
- Installing heat shield on top of turbo.
- The seat in the OR, cutting to fit the new seat mounting bracket assembly.
- Seat installed.
- Installed reverse gear lever, brake caliper and parking brake.
- Installing panels.
- Stretching my 2008 Apex RTX to 136" or 346cm.
- Installing MPI-180 SuperCharger on 2013 FX Nytro TTX.
- Installing pistons and rings. RX-1 Turbo.
Page 69 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-69
- Programming fuel and boost. MCX290 Apex Midmount.
END OF INDEX
Apex MCX260.
- Installing IC.
- Added engine oil.
- Modifying seat.
- Seat installed.
END OF INDEX
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
THREAD INDEX SEASON 2013-2014
- Changing exhaust parts Apex MCX290 Midmount.
- Installing OFT-Racing Aluminum Steering Blocks on Apex.
- Installing USB cable on MCX Gen5 EFI box.
- Servicing exhaust parts on Apex Turbo MCX310
- Installing exhaust parts on Apex Turbo MCX310
- Installing exhaust parts on Apex Turbo MCX310 - putting the sled back together - Done
Page 70 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-70
- Maintenance on my 2003 RX-1 Turbo Sled
- SR Viper MCX270 Turbo Kit Install
- SR Viper MCX270 Turbo Kit Install Manual - UPDATED
- SR Viper MCX270 Turbo Kit Install - Tearing it apart.
- SR Viper MCX270 Turbo Kit Install - Tearing it apart 2, installing head gasket shim.
- SR Viper MCX270 Turbo Kit Install - Checking valve clearance.
Page 71 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-71
- SR Viper MCX270 Turbo Kit Install - Installing engine into the frame.
- SR Viper MCX270 Turbo Kit Install - Installing vacuum lines to the fuel rail, coolant and oil lines, frame parts.
- SR Viper MCX270 Turbo Kit Install - Installing frame parts and wireing.
- SR Viper MCX270 Turbo Kit Install - Installing exhaust pipe, heat Shields, turbo, oil feed and Return lines.
- SR Viper MCX270 Turbo Kit Install - Installing more heat shields, coolant tubes and hoses.
- SR Viper MCX270 Turbo Kit Install - Installing exhaust muffler, O2 sensors, Intercooler and Charge tube hose.
- SR Viper MCX270 Turbo Kit Install - Installing radiator, fuel lines, fuel tank, battery and electrical wires.
Page 72 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-72
- SR Viper MCX270 Turbo Kit Install - Installing MCX BlueTooth box, adding fuel, coolant and oil, first startup.
- SR Viper MCX270 Turbo Kit Install - First testride done. Found a minor coolant leak. Fixed. Sled is ready for a shake down.
Page 73 - http://www.ty4stroke.com/threads/rx...viper-mcx270-turbo-install-done.47473/page-73
- Picked up a "New" sled. 2006 Apex With custom turbo system. Building a 400 HP sled... I hope
END OF INDEX
END OF INDEX
Sportsterdanne
Any pics of the MCX Bluetooth and connectors to it and the Lamda ?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Sorry , no I don't have any pics. I have not been working on that sled as planned. Maybe the owner wants it done this season,if so I will post pics and make a writeup on it.
- 155K
