wshellrider
Posting for a friend. 2010 nytro xtx, 6500 Kms. Recently he’s noticed what can only be described as belt slippage. It seems to happen regularly in deep snow, especially while trying to start, but on occasion it happens on the trail. Any suggestions as to why this may be happening? It’s getting worse over time.
We’ve checked for snow in the clutches, the springs in both clutches are intact, chaincase appears fine, weights in the primary appear to be intact, belt is relatively new and doesn’t show sign of wear.
devilnabludress
How hot are the clutches? Possible soft spring?
might need to scotchbrite the belt surface in the primary as it might be glazed and letting it slip. had this happen on older sleds before.
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
Yeah I would check to see how hot the clutches are. If they are hot then its for sure slipping. I would scotchbrite the surfaces like Maim said above. Also make sure the clutches both move freely without the belt on to make sure nothing is binding up.
1979yamaha
I would check the plate on the bottom that you take off to change your oil filter my was doing the same thing and it was gone
Bottom skid plate missing.Posting for a friend. 2010 nytro xtx, 6500 Kms. Recently he’s noticed what can only be described as belt slippage. It seems to happen regularly in deep snow, especially while trying to start, but on occasion it happens on the trail. Any suggestions as to why this may be happening? It’s getting worse over time.
wshellrider
Thanks for the suggestions. The bottom skid plate is intact. I'll have to check the temp of the clutches.
I don't think snow is causing this as it's happened immediately at the start of day before getting into any snow.
