Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
And yes I searched the FAQ and no dafinitive answer. If I remove the upper tunnel protectors, what is the largest lug I can install and still leave the front cooler protectors in place...I am using 8 tooth drivers vs the stock 9 tooth drivers.......
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
I am going to guess 1.5" . You can do 9 tooth and 1.75 with the guards removed. Did you measure how much clearance you had with 9 tooth and stock track. You probably had a 1.25 ripsaw track as stock. If your changing your drivers , why are you not cutting out the guards while you have the suspension and driveshaft out.
Newfie Apex
- Mar 3, 2010
- 2008 Nytro
I am going to be using 8 tooth extrovert drivers..What is the largest lug I can install with the front cooler protectors in place and what is the largest I can run if I remove them
FX NYTRO XTX 144
- Mar 5, 2013
- Trenary/ muskegon, mi
- FX Nytro XTX 144
1.5" with front cooler protectors, 1.75" without cooler protectors
