Here is the install of the Air Compressor kit from Ulmer Racing. I tried to show mounting locations of switch, gauge, compressor and the line and wire routing that I did. I hope this will help those that want to install this unit into the SE or Mono Shock Fox Float.
Super Sled
- Feb 25, 2009
- Summit X
Looks nice. I like those kits. It I ever switch to a Mega Float then that's a must. Please let us know how will it can adjust air "on the fly" as you bang down the trails. While not recommended possibly, that'd be an awesome feature and how I'd want to use one!
Daranello
Suspended
Can't Yamaha do better paint in the skids?
Nice set up btw. Be cool to do the fronts also and slam it for lake racing
Nick1945
Adjust on the fly now, very sweet
Daranello said:Can't Yamaha do better paint in the skids?
6000 miles on that skid... it would be nice of the paint would hold up better.
sk-rx1
Tom, Have you had anything else done to the shocks, revalve or anything else? I was looking at the Hy Gear mods, looked at Allens kit last year but so far haven't done anything.
sk-rx1 said:Tom, Have you had anything else done to the shocks, revalve or anything else? I was looking at the Hy Gear mods, looked at Allens kit last year but so far haven't done anything.
No I have not done the Hygear mod but was thinking about it. I like the idea of anti bottom bumper inside. If I get some time this week I may call them on it and run that in conjunction with Ulmers Kit.
mshabaz
- Aug 16, 2006
thanks for the pics, will def help......still waiting for the mail guy to drop my kit off!!!!!
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
MrSled said:Here is the install of the Air Compressor kit from Ulmer Racing. I tried to show mounting locations of switch, gauge, compressor and the line and wire routing that I did. I hope this will help those that want to install this unit into the SE or Mono Shock Fox Float.
Nice job MrSled.
Whose tunnel braces are using in your last pic, are they Yamaha ones or aftermarket?
Irv said:MrSled said:Here is the install of the Air Compressor kit from Ulmer Racing. I tried to show mounting locations of switch, gauge, compressor and the line and wire routing that I did. I hope this will help those that want to install this unit into the SE or Mono Shock Fox Float.
Nice job MrSled.
Those are Yamaha Accessory braces.... they had to be notched as shown in the pic, I painted the alum cut edges afterwards.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
MrSled said:Irv said:MrSled said:Here is the install of the Air Compressor kit from Ulmer Racing. I tried to show mounting locations of switch, gauge, compressor and the line and wire routing that I did. I hope this will help those that want to install this unit into the SE or Mono Shock Fox Float.
Nice job MrSled.
Thanks Tom
After many hours of testing and different settings of air pressure I have found that the Air kit added to a stock shock will add too much volume causing the shock to bottom easily if set to ride plush on small stutters. If we crank the pressure to resist bottoming then we find a very harsh ride. As a result we tried the Hygear Re valving and volume spacers as well as the additional anti bottoming internal stopper. See this thread for more info:
http://www.ty4stroke.com/viewtopic.php? ... ght=hygear
yamahahaapex
i cant believe your skid already
yamahahaapex said:i cant believe your skid already
I dont understand what you are saying??
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I initially thought that you were riding a 2011 sled due to the Mega Float shock, but it appears that you have an 08, hence the comments on the rust in your skid.
