DGrabnar
Anyone have any suggestions for the best track out there for the money? Currently looking at a Camoplast intense 121 x 1.5 x 15. for $500. Any reviews on this track? Mostly trail riding with some new snow and no studs.
Any thoughts and/or input would be appreciated.
kurzy
- Mar 25, 2011
- Peterborough On, Can.
- '08 40th. Anniversary Nytro RTX
I have a Ripsaw2 with the 1-1/4" lug. I absolutely love it but when off-trail I sometimes wish it had a deeper lug. I don't run studs and it hooks up like crazy on-trail.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
This has been discussed many times so doing a search will give some good info.
If it's time to replace the track I would at the very least extend it out to a 128" with a 4" rail extensions or skid relocate. A skid relocate works better due to the improved approach angle but both methods are a big improvement over a stock 121". In most cases a 128" track is priced the same as a 121" so the only additional cost would be in the skid modification to accommodate the longer track . I prefer a prestudded track like the Ice Ripper or Ice Attack for the trails but they are pricey. The Tracks USA 128" Ice Attack and rail extensions package costs about $745 and the same track with a skid relocate instead of the rail extensions would be about the same. I don't think the Intense comes in a 128" version.
kurzy
- Mar 25, 2011
As usual, Grizztracks is right again! I extended mine to 136" with rail extensions only. I regret not going for the Star relocate kit. These machines do trench in deep snow and the relocate helps with that. If I had to do it over again, I would've done the relocate kit. Good luck.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I changed tracks last summer from a Ripsaw to an Ice Attack 1.22 (pre studded). Track handles awesome. My only regret I could have extended the rail a bit while it was apart and did not.
MS
MS
DGrabnar
Thanks for the info guys I'm sticking with the 121 as I didn't have problem and had a blast riding it on the ripsaw, just wish to do a little more off trail too
1975FA
I am riding an 08 121 RTX. I put on the 1.5" intense track 3 seasons ago and love it. I do plan on a 128 relocate when I get this track used up.
DGrabnar
Did you have to remove you front tunnel protector (or any of them)? and also are you running studs?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
i have a used studded intense that is in excellent shape.
DGrabnar
Any tear's or rips in the track? Lugs missing? And what are you asking?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
herndonp
Check out the Talon 38 as well. http://www.composit-usa.com/catalog/cross-country/talon-38.html
Pete
Pete
1975FA
I had to remove the protectors on the front heat exchanger to clear. I am not running studs on trails I don't need them with this track, but last winter without much snow icy corners were more of a factor but not a problem.
