Error Code#35
If your getting this error #35 code on Apex/Attak 2006, look for at the wiring harness near #3 spark plug, there may be a wire shorting out intermittently. Most likely it’s the wire that coming out of the #3 plug touching a bolt that secures the #3 ignition coil. Follow the wire up to the black tie rap and inspect that area near the bolt. Reposition the wire strap once repaired to hold the wire up out of the way of that bolt.
Ref: Snow Tech Sept 2007
