SchelT
Can anyone provide a part number for a 4th Idler Wheel kit? Sled is a 2014 Nytro XTX 1.75
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
Contact travis at the Barn of parts... He has 4th wheel kits.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Or just make your own:
http://www.totallyamaha.com/snowmobiles/aaTECH/4th_wheel_kit.htm
SchelT
Ok thank you. Both good ideas. Not sure why Yamaha took the time for three but not a fourth wheel. Easy fix though
nor'easter
I believe that you will also need two spacers in addition to the actual 4th wheel. I purchased mine from Schmidt Brothers Motorsports
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You don't need to buy spacers. You cut the one that's in there now. Unless you want to throw $30.00 in the garbage. Mooseman has given the drawing above in his reply (good show by the way Moose). I used a large pipe cutter. Takes a little effort but it's straight and clean.I believe that you will also need two spacers in addition to the actual 4th wheel. I purchased mine from Schmidt Brothers Motorsports
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
The dimensions for a nytro spacers are the same as the monoshock listed in the link .972... Also the removed slice for the bearing is .472 for a 12mm bearing...
