Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
How have you guys removed the bushings in the a-arms without damaging them. I upgraded to oil lites years ago and they appear to still be in good shape. Planning to take the arms off to get powder coated this summer.
The only thing I can think of is to use a long slotted screw driver, reach in and tap them out; then press the other side out.
Any tips/ideas would be great.
MS
MS
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Just mask them off
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Can you explain 'make them off'. Not sure I understand the term.
MS
MS
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Tape them off.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Didn't realize that would work. I have seen some bushings in so tight - no tape would take them off.
MS
MS
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
I guess he means that you should leave the bushings in the a-arms while powder coating them. Just put tape (mask) the holes in the bushings so no powder will enter the bushings.Didn't realize that would work. I have seen some bushings in so tight - no tape would take them off.
MS
Broue
- Feb 28, 2015
- FX Nytro XTX 2009,
Factory race front end
Star suspension relocation kit and revalve
Ski Doo #503192064 center spring
135 mm idler wheels
Oilite bushings
Grizz steering relocator
Tuner ski : 6 ''carbides,
WRP seat
Vector gauge
Custom Taillight
LinQ tank
Sno Sport 1990
Ski Doo Tundra R 1998
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Cool - didn't realize such a tool exists.
As for the tape. I didn't think you could place anything like that on the part as it wouldn't take the curing part of the powder coating process. Wouldn't the oven bake it off and make a mess?
MS
MS
Mountaintech
Gotta take them out for powdercoating. The temps will bleed the oil in the bushings out.
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
I work for a company that has stuff powder coated everyday and yes you can tape them off. We have our powder coater mask all the threads on our parts so they should be able to mask the bushings no problem. I'm actually going to be doing the same to my sled this summer.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Hey Deepow,
Since you know more about powder coating than I, at what temps do they bake at?
I know when the bushings were put in they were greased so they pretty much have to come apart to clean them up.
I don't think you can risk having any oil or grease that may run/drip onto an area to be painted.
MS
MS
Deeppow16
- Oct 19, 2015
There are 3 stages they do, 1 is a softening temp of 176 degree F, 2 a melting temp of 302 degree F, 3 and parts are cured at 392 degree F for 10-15 min. These numbers can vary a bit depending on how thick the powder is applied and the type of powder used (particles can be bigger or smaller). Also they will wash your parts with a special cleaning wash before they paint them to take any oil/grease off. A lot of the parts I have powder coated are bare steel that has oil on the surface from the place we get our steel from. Hope this helps.Hey Deepow,
MS
Mountaintech
If you subject Oilite bushings to those temps the oil will "bleed" out. Oilite bushings are inpregnated with oil, hence the name.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Thanks, that confirms what I suspected. Appreciate the help
MS
MS
1975FA
Try pulling them with a pilot bearing puller.
