kingedwards99
I put my battery on a battery tender every year since I bought it, and when I went to start it, it was dead. So I put it back on the tender and it said full, hooked it back up and the key worked started it and it shut off, started wiggling, some wires around and it started flickering around on the dash. Make a long story short I found that from the key switch to the first plug in was what was wrong, I opened it up and found the prongs on the plugin were corroded, so I took some electrical grease and worked it back and forth and it is as good as new.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Common problem.
