cw xtx 1.75
- Jun 12, 2014
- 2013 Yamaha Nytro xtx 1.75
Rode my sled yesterday . Now when I start it up on the stand in my garage the track starts spinning at idle . It is a 2013 nytro xtx . Do I need to adjust my deflection ?
herndonp
Track should just barely move on stand when at idle. Means deflection is close to perfect.
Pete
Pete
cw xtx 1.75
- Jun 12, 2014
When on the snow at idle it also wants to inch ahead . And will move if I don't hold the brake.
herndonp
Should'nt move on the ground. Only on stand.
Pete
Pete
cw xtx 1.75
- Jun 12, 2014
It does slightly if it is on hard pack or ice . Do you think deflection is the problem?
herndonp
It should'nt move if your sitting on it on ice or hard pack. Could be belt is to tight (deflection) or clutch issue.
Pete
Pete
cw xtx 1.75
- Jun 12, 2014
It doesn't move if I'm on it but if it is sitting idling by itself it will move slow.
herndonp
You should be alright then
cw xtx 1.75
- Jun 12, 2014
Do u think it should move by itself ?
herndonp
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
As my clutch was getting older it did the same thing. Once I had it rebuilt in was back to normal. Perhaps its time the primary had some love. MS
cw xtx 1.75
- Jun 12, 2014
I hope it just needs some shims . My sled only has 750 miles on it .
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Then that seems odd. I just assumed it was an older clutch. Something is out of wack then. MS
herndonp
Did you check your belt height against the info I gave you?
Pete
Pete
cw xtx 1.75
- Jun 12, 2014
So ended up taking my sled in . They found a broken primary spring . Seems odd with only 750 miles on my sled . Is this common on nytro ?
