pay2play
I think I'm going to remove my tunnel protectors for ice build up reasons. I plan to put on the 1.75 back country track (someday) anyhow and they'd need to come off. I see the block off plates by OFT and Schmidt bros. How do you like them?
Twistgrip
I have the Schmidt bros block off plate, nice fit and finish and it cuts down on the ice build up nicely.
TRiGGeR605
I just checked out both the OFT and Schmidt bros plates. The OFT looks better in my opinion. With the pictures displayed of the actual install, the OFT looks like it blocks more. Downside is that the OFT is 40 bucks more.
pay2play
My thoughts exactly, just wasn't sure if it mattered. Hope to get some real world reports.
srx901
if your using a stock muffler I have a Schmidt bros plate I will sell you its used but in excellent shape I installed turbo and I cant use this anymore
pay2play
Pm sent
I have oft nice piece but had some interference with stock exhaust and had to cut the opening slightly.
Could You email pictures of where the clearance was needed to Rick@OFTRacing.com I have had no reports of issues so I'd like to see what was going on.I have oft nice piece but had some interference with stock exhaust and had to cut the opening slightly.
Thank You,
Rick Coffman
pay2play
Rick, I'll be ordering your plate. Looks very nice. Hoping to avoid a block of ice under the tunnel. Took off the stud protectors too. That should help a lot by itself.
It was on the u shaped cutout where the exhaust cones through. The pipe was touching. When I take the sled out of storage I will try to remember to take a photo.Could You email pictures of where the clearance was needed to Rick@OFTRacing.com I have had no reports of issues so I'd like to see what was going on.
Thank You,
Rick Coffman
Thank you for your order! They are in stock and should ship Monday.
Thank you, feel free to post it up here. If its a problem others are having hopefully they will chime up and its really easy for us to adjust the cutout if needed.
YamBam
I ran Schmidt Bros. last year. Worked fine.
TLM
- Jul 19, 2014
- Hortonville, WI
- 2012 Nytro xtx, oft relocate, oilite bushings, comfort clutch, tunnel block, tailight relocate, cr10EK plugs, copper donuts, tuner skis, Grizz Tracks gusset kit. Excell x wheels. Mo-Flow console vent and curved vents.
I fabbed my own with a sheet of aluminum.
