Twistgrip
Bought a new Trail Tank from Haydays yesterday. I have 2400 miles on my 2013 Nytro XTX with 3 years of warranty left, should I change the donuts even with all the warranty left? The exhaust sounds perfect.
Yes. You are already in there. Co with the copper ones. Also, figure out the right size for the fuel pump bolts and go buy some better ones, the ones that come with it are prone to snapping.
pay2play
Are the poor bolts a reason people are having leaks? I don't want to ruin a trip because of a leak when I put my trail tank on. Any suggestions out there . I too ordered copper donuts just because.
herndonp
I changed mine (copper donuts) when I installed my trail tank. Your already in there might as well do them. I had about 2500 miles on the sled the OEM gaskets were slightly worn but not leaking, I like piece of mind so changed them.
Pete
Pete
Twistgrip
Where can I get the copper donuts?
Twistgrip
I found it, Oft or sledtoyzWhere can I get the copper donuts?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Get them done while your in there. Also think about changing the plugs. The trail tank uses up the clearance at the head of the engine so you can no longer get at them once it is installed.
MS
MS
Twistgrip
Yep think I'm going to, just ordered thing!e copper donuts, steering relocate and the mo fo vent from Oft racing!Get them done while your in there. Also think about changing the plugs. The trail tank uses up the clearance at the head of the engine so you can no longer get at them once it is installed.
MS
Put some permatex sealant around the fuel pump mine leaked after 1 season
pay2play
Bummer. Seems like there are a number of issues with the TT. Oh well, I'll contact Seth to get his opinion on sealing the pump and the bolts that seem to break on some.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Luckily I have had no issues with mine. Look into getting the longer dzas fasteners for the centre cowl, it makes lining things up much easier. Once you get the tank installed on that sled it is a game changer. Last year was amazing with the new range i had and the fuel stress was gone. MS
moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
I bought one at haydays as well, I'm interested to hear more about the bolts for the fuel pump. If they are still a problem with the newer tanks I'll go and buy some stainless bolts. I don't mind having to remove the tank to do work, but definitely want to avoid any leaks.
Twistgrip
Yes please more opinions on the bolts. I'm going to get new ones anyways but I'm still curious on your guys experience with the tank. Looks like a nice addition to the sled can't wait.I bought one at haydays as well, I'm interested to hear more about the bolts for the fuel pump. If they are still a problem with the newer tanks I'll go and buy some stainless bolts. I don't mind having to remove the tank to do work, but definitely want to avoid any leaks.
pay2play
I put a flat edge on my TT fuel pump opening. It is fine all around the opening but where the nuts are set into the plastic there is a variation to the level at the opening. It is higher. I'm guessing that this is why some can't get a good long lasting seal on the fuel pump without permatex or stronger bolts.
weasel33
I never had any problems with mine. Possibly one of the best upgrades you can do to a nytro. Just watch topping it off to high when filling with gas because once you put on the cap and the gas warms up a little it pressurizes the tank and pushes gas out the vent line.
