whitewheels
Please any suggestions how to get this unstuck?
....and yes I have loosen the little torx nut
This always just fall out but this time it won't budge. Can move it slightly counter clockwice but it wont move out.
Skickat från min SM-G389F via Tapatalk
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Tap the top of the chain case and it should break lose.
whitewheels
Ok....if I dare....will try for sure but it's pretty stuck.
I'm thinging something is wrong when it's stuck like that....
APEX 06
- Apr 30, 2009
- Sheboygan, WI
More then likely a little rust. It should move easily with the case
Dr. FeeLGooD
This is some amazing stuff. Leave it on overnight if possible. Acklands has it where I live.
https://www.aircraftspruce.ca/catalog/graphics/09-02665.jpg
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Gently use heat from a heat gun, a little Kroil and tap it lightly. Should come loose.
MS
MS
whitewheels
Well had to swallow my pride and call my dealer. He recomended this...
Tap the axel from the other side and it came right of [emoji4]
Dr. FeeLGooD
Thanks for sharing !
herndonp
That was a good trick. Thanks for sharing and letting us know. Mine came off easy when I pulled the drive shaft this past summer to change the track, but its always good to know some extra tricks in case it did'nt.
Pete
Pete
