Here is some info on Castle X snowmobile gear for this year!! See more athttp://www.castlesales.com/
http://www.totallyamaha.com/Totallyamaha/CastleX Review 2015/CastleXReview2015.htm
superfan75
They have some good looking apparel. I'm thinking of some new boots, has anyone tried the Castle boots ?
I have.. they run a little on the big side when sized... very warm and keep your feet dry. What else would you like to know?
superfan75
That was pretty much it I guess. Actually how do they hold up and are they fairly light ? I'd like something lighter and easier to walk around with than the big pak boots I have now. Thanx Mr Sled for your input.I have.. they run a little on the big side when sized... very warm and keep your feet dry. What else would you like to know?
I like the Force Boot more then the Barrier... They are both fairly light but the tie boot I can snug up more then the other.
http://www.castlesales.com/snow/mens-snow-apparel/mens-boots/
superfan75
Hey Thanx for the input. I may get a pair when the tax return comes in. I've had the same boots for over twenty years, I think its time for an upgrade. LOL
superfan75
Just for an update Mr Sled I got a set of the Force boots and I do like them. The only issue I have so for is that they don't like to bend backwards very much. When I sit down I need to have my ankle bend back a little. With the flat floorboards and low seat on the Warrior its more of a problem than other sleds I guess. By the time I got home my calf's were sore from the top of the boots pushing in on them. I assume they will break in and be more comfortable though. I really like how their built and the size and weight is also very nice. I only have one ride with them so far so I'm sure they will get better. Thanx for you input.
I agree, they will take sometime to break in. What i did to help that is I kept them laced really tight and did not use the top 2 eyes or loops.
superfan75
That's a good idea. I tried leaving the laces a little loose at the top, but not lacing up the top two eyes unlaced would let my leg lean or bend back easier. I'm wearing them as much as possible to break them in. I even wore them this morning while I was snowblowing the driveway. Another six inches of snow. WooHoo !! Thanx again.
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
I always skip the first eyes/loops on the shaft of the boots on all of my boots, helps a lot
ManhattanMike
- Jan 29, 2008
- Mokena, IL
- 2020 Sidewinder SRX LE, 2018 Snoscoot
I swear I rode with these models two weeks ago.
Lmao... you may have
- 13K
