vetcorman05
- Oct 27, 2013
- Fairfax,mn
- 05 vector,94 vmax,92 indy, 95 jag deluxe
How were the trails? We were up in mercer a couple weeks ago and it was good riding. the vector is a fantastic sled!
Catman, the rpms on WOT is controlled by the weights in the primary clutch. did you just drop in the spring? The 2012 Apex showed highest power at 10100 rpm, so being around 10k sounds just about right. About 1.5 hp less according to that dyno test. No clutching will change top speed - if it has enough power. however machining secondary will
theCATman
Trails were good, but alot of snirty areas til late in the day, by then the temp (36*) & heavy traffic had them beat. Corners were pushed out bad & whooped out sections.
We went for a short ride Sunday morning, went E/SE of Tomahawk, & they were alot better. Much less traffic. They need a good 6-12" to freshen up.
vetcorman05
- Oct 27, 2013
- Fairfax,mn
Thanks,we are hoping to get up that way once more this winter.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
anyone running this on a 11 or newer apex? Will it help with the groove I am getting in my primary where the belt engages and the squeal i get on engagement sometimes?
BigDogrx1
Would be best to call and talk to Chris@Scmidtbros 9897562150 he knows CLUTCHES, all set ups are different, Larry
grumpysanta
150 for spring and rollers for nytro
