jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
Looking at dumping some money into the Nytro. I'm tired of being a snow submarine, and I hear the oft kit is a must have. What can you guys tell me? Does anyone have a set of the skis they would part with? I'm a Canadian so I expect that puts me at a disadvantage.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
About the relocator so can you read loads of threads about that. I have not heard a negative thing about them, so go for it.Looking at dumping some money into the Nytro. I'm tired of being a snow submarine, and I hear the oft kit is a must have. What can you guys tell me? Does anyone have a set of the skis they would part with? I'm a Canadian so I expect that puts me at a disadvantage.
herndonp
Love mine. It is one of the best upgrades for the Nytro.
Here is a link for more info and installation instructions. The scariest part of the install is bending the lower studs (just take your time and pay attention)
http://oftracing.com/OnlineStore15/index.php?main_page=product_info&products_id=85
Pete
Pete
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
The relocate is pretty straightforward. Removing the bolt on the tie rod give me some problems. Its a pressure fitting so it can stick bad. A pickle fork, or small pry bar to release it can help. Even heat from a heat gun will help release it. If there is a bit of corrosion it can be stubborn.
When I did mine, the instructions did not give you the heads up this part of the install that can cause a hic up. Seems like experienced guys have no problem but this was new to me and was a PITA.
MS
MS
