Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Just replaced my donuts today with copper ones.
How tight do you tighten the bolts on the clamp?
Do you really tighten the bolt or just snug it up.?
Since this part is subject extreme heating and cooling cycles, I would think it needs to be tight.... The manual indicates 6 ft lbs. ....that can't be right.
Ms
Ms
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Super tight if them come loose your donuts will leak
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F, '79 Trail Fire
I tightened mine snug and then put about a 1/4 turn more into each bolt.
NS FX NYTRO
The clamps have a stop on them that will prevent over tightening. A lot of people grind a little bit of this stop tab away to allow further tightening. I tightened mine until it basically bottomed out on the stop.
- 10K
- 32K
