Yamadog
Last year some one posted the Arctic cat gearing chart vs speed mph for the 7000 on here I thought I saved it but cannot find it. I tried a search to no avail. if anyone has it can they repost it or pm me!
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Ok nice chart what does my ltx se 2014 have for gears? What does the xtx have?
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
x2Ok nice chart what does my ltx se 2014 have for gears? What does the xtx have?
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
LTX= 24/50, XTX= 21/41
I use an app on my Iphone called Speed Calc and it works great. Input your RPM, Gearing, and drivers and pitch and it gives you speed.
4StrokeAddict
- Apr 13, 2015
- Michigan
Ok, why don't I see 50 on the chart?
stingray719
I tried 21/50 and the chain was too short, I suspect ratios that will not line up with the chain are not listed.
Pstn head
What does an RTX DX have for gears and pitch ?
Yamadog
Thanks Sas I was away from computer all weekend
Yamadog
I will tell you that mine has 21/41 with 10 tooth 3.0 pitch drivers and it did 117 on Ulmer's track dyno but even with 252 hp and overdrive and machined clutches best real world MPH is 108
Yamadog
I guess 24/35 is the next step lets see how close to 150 we can get !!!! adding about 70 hp should be a blast
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
anyone know what the 16 xtx comes with as for gearing and drivers? I would look but I don't have it yet.
stingray719
Is yours coming with the 2.6 powerclaw? If so I would bet 21/49 and 7 tooth drivers but that is just a guess.
Studroes144
Real hard to pull the overdrive in real world, my opinion is that you mights well gear for the speed you want or even a tad faster then you're clutches are always running efficient, as we know, clutch efficiency really drops once you start in overdrive.
InRBigness
- Apr 10, 2014
nope it is coming with the 1.6 Cobra track.
