jremps
- Mar 2, 2014
- Manitoba, Canada
- 08 Nytro 40th anniversary
Anyone having issues with these connectors? Are there any remedies? I have seen someone cut them off and soldered the wires together for a solid connection. They haven't had any issues since.
I had multiple codes and a no start backfire while cranking and i ended up probing these grounds and eventually the codes went away and fired right up (after changing plugs and a starter that grenaded because of the backfire). Also had a tors code that i think was fixed by wiggling these connectors also.
sprintcat
What's this ? Is it a plug? Left side of sled under the radiator?
Grimm
I think it might be a plug in for the Dealer for diagnostics.
Sent from my D5503 using Tapatalk
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Check the harness behind the primary. There is a casting nub that rubs through on the 08/09 models. You can either file down the nub or do a hold off with a large tie strap. But check those wires.
