yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
Hi.
Anyone have an ide on how too reduce the gyro effect from the engine?
Is there any parts that can be changed or modified too reduce the effect?
Any ideas?
Any ideas?
chris189
- Nov 27, 2011
- Hanover Ontario
- 2007 Apex GT, 1980 Enticer 340
Do you mean engine braking or the gyro effect like when your is the air and cracking the throttle to make the front end come up? Same as hitting the brake for the reverse?
yamahamm
- Oct 9, 2009
- Norway
I mean the effect in the engine that works against you when you want the sled to turn left or right when boon docking or climbing steep hills.
Lightened crank, clutch, brake disc, drive shafts, track, everything what rotates with engine. I can feel when rotating mass is against me, but it is only when rpms are very high. I cant feel it an issue, it just calms sled behaviour in high speeds.
First of all, change your front end with at least 3" forward. Then you can control your sled and change directions and have same kind of feeling like rmk/m sleds.
Second, lowering the mass center of your sled, like removing upper radiator and lighter battery, "smaller" fuel tank or something that is not so high than stock.
The front end is really an issue of this sled when boondocking. Turboed sleds have easily 30-50% more track speed when hitting wide open, so it really has more rotating mass in same situation than "normal" sleds and always when track speeds are high, but I can't see that an issue, it is more like positive issue. When climbing with nytro, skis don't usually touch the ground so then there is only rotating masses and you. Adjusting handlebars might help a little, maybe different riser or just shape of handlebars is answer, but it still wont get anywhere from unpredictable front of nytro. I mean, even with turbos, sometimes skis have to come down..
If you still feel that rotating mass is an issue, get/make nypex, then there is two rotating mass against each other and sled will be something else to drive. I would like to test one sometime..
yamahamm
- Oct 9, 2009
- Norway
Yea i have a lighter battery(11 lbs lighter then stock) cut off the cooling fins on the brake disc and i have removed the sway bar. next on the list is a new front end.
But i just want ideas on how to make the sled even better because i love the nytro as is but i always want it to be better And yea i have a MCX 270hp kit on it too
yamahamm
- Oct 9, 2009
- Norway
Drive shaft i might take a look att tho.
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
If you can feel a difference with a lighter battery and the cooling fins removed from your rotor you are more in tune with your sled than I am!
Sway bar removed I can understand!
Mountaintech
The gyro effect was even worse on the wider, higher revving 4 cylinders. Changing the front end will make it handle like a different sled.
yamahamm
- Oct 9, 2009
- Norway
i didn't say that i can feel the difference with just those mods. I just told what i have done to the sled. I'am in the progress of making the nytro a better ride and just need ideas on what to do.If you can feel a difference with a lighter battery and the cooling fins removed from your rotor you are more in tune with your sled than I am!
yamahamm
- Oct 9, 2009
- Norway
I know that, but it won't change the handling when the skis are off the ground, thats when i feel the engine working against me when i want to make it turn around.The gyro effect was even worse on the wider, higher revving 4 cylinders. Changing the front end will make it handle like a different sled.
