stomper
sgauthier
where's the crack? i see the casting marks and a scratch. are you referring to the line going down from the plastic button?
stomper
Yep. From the corner. Trust me it's a crack. Not sure why it would crack there. Wouldn't think there would be much stress in that area
Ding
I would likely replace it as soon as feasible. Luckily you can get used secondary clutches pretty cheap on here. It would likely stay together for a while, but it could go at any time. Curious why it cracked there. The forces just aren't that great right there.
stomper
Yeah my thoughts exactly. Yeah there are some good prices on clutches here but Things add up real quick when you are from north of the border. Dam shipping and exchange rate.
i have 2 secondarys that cracked there in my garage. my theory on it is too sudden a transfer from hard on the gas to hard on the brake. youngest brother did that to both of the clutches riding like that. we converted him to a roller set-up and he has had no problems since. clutch works off of any sx sled too after you change over helix and spring. both happened on rx war sleds off trail (we think) at the time.
Ding
I was wondering about them slamming shut like they can do. My Attak does that especially off-trail. My SX Viper has a roller so it doesn't do it either.
stomper
Good to know. I don't think I drive like that, hell, I barley use my brakes when ribing the trails. I let the engine do the braking. But I'm sure it has happened, I just wasn't aware of it. Either way it sucks
stomper
I found a secondary from an 06 apex. Would that work if I put the spring from my clutch in it.
- Jun 28, 2004
- Clinton, Wi.
Yes!
rangermike14
- Feb 19, 2015
- Byron Center, MI
- 2006 Apex
1998 SRX 700
Friend has an RX1 that he just replaced secondary because all three where broken off. Just going to get worse. Replace!
stomper
Wow. Never knew it was that common
