edge_232
- Jan 15, 2014
- Madison WI
- 2011 Nytro MTX slowly being modded
2005 IQR Trail Converted
So I got my oil change all done, (thanks to the guys that posted on my question before) but now my warning light is on solid not flashing and when I press and hold the reset button I get the word "OIL" and then the number "00409" flashing? I do have a Vector gauge on my Nytro but everything has worked fine fine.
When I first finished the oil change the warning light was not on but as when I topped the oil off to the correct level I did forget to reconnect the oil level connector to the plug and fired the sled up. I believe this tripped the warning light and code. I connected the oil switch and still get the warning light and code.
I looked in the manual and in the forums but couldn't find anything on this code.
Any ideas or do I just need to reset the gauge?
I think you just need to reset the gauge. basically it is saying you are 409 miles over your oil change. freaked me out when I saw it the 1st time as well.
link on how to reset it on an apex. should be the same for an rs I think.
http://ty4stroke.com/threads/reset-oil-change-warning-on-display.116599/#post-1034398
natedawgedog
http://www.ty4stroke.com/threads/oil-change-reminder-message.88584/
here is the topic from a little while back.
edge_232
- Jan 15, 2014
- Madison WI
Thanks Guys, I'll give it a try tonight and let you know how it goes.
edge_232
- Jan 15, 2014
- Madison WI
It Worked Perfectly! Thanks Guys!
