SISCAKIDD
back in 04 i bought a lite battery for my warrior and it worked great,now i would like to get on for my nytro,but don;t remember where i got it from,any body have any suggestions.
SISCAKIDD
thanks matt
08NitroRTX
Looks like the same bat/cap that is now called the model 400. Simular specs...
http://cgi.ebay.com/XSTATIC-Batcap-400- ... dZViewItem
asrx600guy
I would have thought capacitors would discharge fairly quick (relative to traditional bateries) while sitting.
mmmkokanee
maxdlx
so what is the concensious, is this batcap the same as Mtn perf battery. Maxdlx
08NitroRTX
OK I looked through the list of sponsors for this site and I did not see Mountainperformance as a site sponsor. IF they are and I missed it I"m sorry and mod splease deleat this post! or PM me and I will.
That being said.....
maxdlx, Here is a pic of the bat/cap I picked up with the same specs as the Mt performance battery
I'll let you compare prices.
Both of the local high end mobile stereo shops said YES this bat/cap will work fine. One of the shops did mention that at temps well below 0 (F) (like -25) is the only time I may have a problem, but on normal riding days he said it will work perfect!
We'll see!
We'll see!
maxdlx
I found them on ebay cheap. You can get the really lite weight 300 for around 130 shipped, and the 400 for 165 shipped. I'm thinking the 300 on a 6500 mile motor might be enough, and 2.5 pounds would be sweet. Maxdlx
maxdlx
anyone running the smaller 300. I need some input on this. Thanks Maxdlx
Heres another thought, 2 300 have more capcity than 1 40 and weigh the same, but could be mounted in 2 differnt spots, to move weight back some towards the center of the sled. Any electrical guys here. Maxdlx
08NitroRTX
maxdlx
I looked at trying that (2 model 300) but other than like you said 2 different mounting places (could be both good and bad) the cost offset the the little bit of additional power of the 2 model 300 MAY have is not worth it.. IMHO.
2 model 300 weight the same as 1 model 400 (5lbs) BUT there is really no more power!!!
Look closely at the specs
One Model-400
400 - peak starting amps (for up to 8 seconds)
1hr - 5 amp draw
5min- 28 amp draw
5lbs - weight
Two Model-300
600 - peak starting amps (for up to 8 seconds)
2hr - 2.5 amp draw
10min- 14 amp draw
5lbs - weight
So actually other than peak amps 2 model 300 are actually equal to OR less than 1 model 400 IF we were to compare the same amp withdraw or load!!!
Darn advertising trying to trick us!!! lol j/k
One Model-400
1hr - 5 amp draw
5min- 28 amp draw
5lbs - weight
Two Model-300
2hr - 2.5 amp draw
10min- 14 amp draw
5lbs - weight
