Matthew457
GYTR GEARHEAD
look great !View attachment 112056 View attachment 112057 View attachment 112058 Got it installed and just waiting for my turnout to come in! Looks great! Just gotta add more wire to the tail light to make it fit.
Matthew457
GYTR GEARHEAD
Matthew457
Nice, too bad it didn't slide on rails tho, straps are annoying sometimes but it looks like it will work well.i went with the brp jug it
Matthew457
How much fuel does it hold?i went with the brp jug it
GYTR GEARHEAD
she hold close to 13 liters or 3.4 gallon it will make a difference for sure ! buddy of mine has one install on is XF1100 turbo its been 3 years she never came undone and the strap still in pretty good shape .... she was pretty cheap 115$ tax in on saleHow much fuel does it hold?
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
View attachment 112136 View attachment 112137 View attachment 112138 View attachment 112139
Thanks! Also got the turnout installed now!!
If you didn't do so, I would recommend drilling additional holes to install the turn out. I found that the vibration would eventually cause the turnout rivets to fail. I actually had the turn out fail and spin down and melt my Linq can a little before I caught it. I repaired it with better rivets and it happened again. The final fix was to install 4 rivets 90* apart (basically 12, 3, 6 and 9 o'clock); it hasn't moved since and is still nice and tight.
