Matthew457
How to keep the wires running in the tunnel to the back protected from ice and how to keep the wires attached to the tunnel? Anyone just put the stock light in the holes for the reflector?
HRD2PLZ
I put a "knight rider" led light on the back of the tunnel. Light is from Custom Dynamics. I drilled a hole down through the tunnel protector from stock location on top of the tunnel and ran the wires through it back to the light position. Are you able to visualize that? If not, I can take some pics and show you.
Matthew457
Did you keep the plug in that's in the middle of the wire or just get rid of it and make it one wire so that it can't be taken off without cutting the wireI put a "knight rider" led light on the back of the tunnel. Light is from Custom Dynamics. I drilled a hole down through the tunnel protector from stock location on top of the tunnel and ran the wires through it back to the light position. Are you able to visualize that? If not, I can take some pics and show you.
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
I bought a 3 ft section of air compressor hoes at he local hardware store and a couple clamps and ran the wires through it. Works great and since the hoes is flexible you can run it where ever you want. I did not keep the plug because I had to add wire anyways so I cut it out.
Matthew457
So you just have one straight wire, right? Like you would have to cut it to put a be light on?I bought a 3 ft section of air compressor hoes at he local hardware store and a couple clamps and ran the wires through it. Works great and since the hoes is flexible you can run it where ever you want. I did not keep the plug because I had to add wire anyways so I cut it out.
Deeppow16
- Oct 19, 2015
Well there should be 3 wires a running light, brake light and the ground. I cut the plug off on both ends (sled side and the light side). Then I added my extra wire I needed, pulled the wires through my hoes, and got some waterproof wire connectors and heat shrunk them together.
Matthew457
K cool, probably what I'll doWell there should be 3 wires a running light, brake light and the ground. I cut the plug off on both ends (sled side and the light side). Then I added my extra wire I needed, pulled the wires through my hoes, and got some waterproof wire connectors and heat shrunk them together.
Deeppow16
- Oct 19, 2015
Yeah it was pretty easy to do and didn't take much time at all. It gives the sled a much nicer look having the wires run under the tunnel instead of on top of it. I enjoy doing little projects like this.
msgt van
I ran mine down the outside edge enclosed channel of the right side running board.
HRD2PLZ
I cut the wire at the back and soldered it then shrink wrap. 3 wires. I'll get a pic up later.Did you keep the plug in that's in the middle of the wire or just get rid of it and make it one wire so that it can't be taken off without cutting the wire
Ray Reed
I put a generic tunnel rack and ran the wire in wire protector along the inside of the new rack and attached the light to the reflector holes. I did run electrical tape around the outer parameter of the tail light to keep snowfrom behind the light
Matthew457
Pictures?I put a generic tunnel rack and ran the wire in wire protector along the inside of the new rack and attached the light to the reflector holes. I did run electrical tape around the outer parameter of the tail light to keep snowfrom behind the light
GYTR GEARHEAD
GYTR GEARHEAD
i reused the stock reflector bracket its pretty solide i rerouted the wire under the tunnel incase in a plastic tube all i had to do is to cut a small window on top of the snow flap to get the wire trought
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
Nice job. If you had drilled out the reflector bracket rivets, the holes line up with the light mount holes and you would not have needed that bracket that you made.
