THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Sled has a 144 studded down the middle. I'm seriously thinking about removing all the studs. I can't see any issues running a "holey" track but thinking I might be missing something. Any thoughts?
smoothride
Did my track on my attak. Just use a cut off wheel and cut them all off.
THKSNOW
Smooth Operator
- Aug 11, 2006
I'd really like them all out, not cut off.
smoothride
Good luck they will be hard to unbolt after being in there a long time. When you are tired of trying to get them nuts off. Cut off wheel it is. Or torch if you have one.
Most people do cut them off using a cutoff wheel or even a bolt cutter since they often won't unbolt since threads get buggered up from use. Quicker also.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I have removed quite a few. Just put your impact gun on them and most of the nuts will come right off with the track holding the stud. Usually only the bent ones are a pain.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I believe they mean to cut off through the nut, so they gone just ad though they were disassembled to take off. I have taken them off and run track without issue
IA Rider
- Oct 12, 2009
- Floyd County, IA
- 2017 Ski Doo Enduro 1200
Like STAIN said impact gun then cut the nut on two sides to get the rest. Impact will get most of them.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
no problem at all running a track with stud holes as long as none have pulled thru and if they have risk is no higher then if you left them in if anything risk is lower do to less spinning mass.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F, '79 Trail Fire
its not a bad idea to use a small propane or other type of torch to burn the edges of the holes (both sides of holes) to keep them from cracking or the internal fibers from fraying and tearing when you use it without the studs.
THKSNOW
Smooth Operator
- Aug 11, 2006
I appreciate all the comments, thanks. There's only 1,300 miles on the sled (maybe less on the studs) so they should all come out without much problem.
THKSNOW
Smooth Operator
- Aug 11, 2006
Thank you all again. My lightweight 12v impact did the job just fine. Studs look like new, probably only have about 1,000 miles on them.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
perfect
benjamingvsu
- Oct 9, 2007
- Stevensville, Michigan
- 2014 Viper rtx se
Just curious why you took them out? I haven't used them since I threw one through a heat exchanger on my zr8 and realized the new ripsaw I put on after that debacle hooked up better than my other studded sled at the time. But, I've been considering studding my Viper to get a bit more holeshot.
THKSNOW
Smooth Operator
- Aug 11, 2006
I think they cause more damage (especially to the track) than they are worth.
