shughes
I have wanted to try a 4 stroke for a few years now and I just got a great deal on a 2013 XTX 1.75 that was still in the crate.
I have about 200 miles on it now and I have a bunch of new parts going on now.
While I have it apart is there anything anyone can recommend that I should be doing now?
Below is the list of parts I am doing now.
MPI Stage 1 supercharger with cold air kit, upgraded blow off valve and clutching.
MPI super sized tunnel cooler
PMT steering relocate kit
Simmons Gen III Flex Skis
Sled Solutions Lightweight Float plate
Fox Float R EVOL front shocks
Schmidt Bros Clutch guard and left wet foot plate
Yamaha Mid Height Windshield and side deflectors
Yamaha rear tow bumper
Yamaha rear storage rack
I am looking at adding a trail tank and possible gearing change.
Also I would like to see about removing the stock heat exchanger in tunnel if it will allow me to then stud the track. Riding here in Maine can be tuff without studs.
Any advice will be greatly appreciated.
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
Ride it hard!!
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
Re: New 2013 Nytro XTX 1.75 Upgrades - What else should I do
Replace the lead acid battery with a lithium battery, that will give you a 11lb weight loss, double the cold cranking amps and last twice as long.shughes said:I have wanted to try a 4 stroke for a few years now and I just got a great deal on a 2013 XTX 1.75 that was still in the crate.
shughes
Thanks for the tip. I just ordered a EarthX.
Nytro40th
- Sep 19, 2007
I have the same battery now in my viper and have been using it all season with no issues.shughes said:Thanks for the tip. I just ordered a EarthX.
Dodge Ram
Tunnel block off plate. Mountain tech skid plate( A must have!!!)
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
I would get larger idler wheels and a set of ice scratchers
Cherry08
Grizz gusset kit too...
shughes
Where do I buy the gussets?
terez
basic700 said:I would get larger idler wheels and a set of ice scratchers
Correct me if Im wrong here but dont the late model Nytro's have larger idlers as stock oem equipment and don't require upgrading??
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
I have never heard that. But am not 100%terez said:basic700 said:I would get larger idler wheels and a set of ice scratchers
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
If you ride at night HIDs are awsome!
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
your sled is going to rock !!
I also just ordered the MPI supercharger kit
Check out the JRE Spindle, would be the icing on your sleds cake.
Cherry08
shughes said:Where do I buy the gussets?
just pm grizztrack he is a member on here
