new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
my buddies 2010 xtx is bogging after it warms up changed plugs 2new tank gas with sea form switched coils checked wiring change tbs tors set and still bog anything we and dealer are missing ???
Gary Boutilier
Any idea what rpms the bog is at, my 08 rtx has similar problem and can't figure out what is wrong it is doing it at about 5000 rpm and only once it warms up
new rob
- Oct 18, 2009
- Viper rtx
Just found bare wire (yellow) behind clutch young rob just went up & down lake a couple times works good. It was bogging for about 10 sec ( felt like on carb machine flooding) & slow acc then went ok only did when warmed up seems good to go now
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Check for the normal rub behind the secondary. That casting nub will cause a lot of grief on the harness if not dealt with. Common problem.
Alphadog
- Mar 6, 2015
- Appin Ontario
- 2018 Sidewinder
thanks for the heads up just checked mine and it started toCheck for the normal rub behind the secondary. That casting nub will cause a lot of grief on the harness if not dealt with. Common problem.
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
I had similar issue, opened up harness had yellow wire rubbed also. Fixed it, tied harness out of the way from rubbing again, seems fine now.
