SchelT
AHHHH! Can't seem to find anyone that carries an upgraded front track (center) shock for my 2014 Nytro XTX 1.75! Looking to find a FOX Zero X, Coil over, Piggyback reservoir, 13.25" length center shock. Doesn't matter what color the spring is. Any suggestions?
sledheadgeorge
Put the heavier spring from the RX-1 on that front shock.Won't blow thru the stroke and it will handle the bumps much better.
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
I have a set of exits I'd sell. The center one is 13.25/13.125 depending on how close I measure. Have the rear one too ideally I'd like to sell as a set but....
SchelT
Exits?I have a set of exits I'd sell. The center one is 13.25/13.125 depending on how close I measure. Have the rear one too ideally I'd like to sell as a set but....
mysledblows
- Jan 23, 2007
- Central MN
- Jenkins, MN
exits shocks. Z broz racing
SchelT
XO? X1? or X2? Price?exits shocks. Z broz racing
mysledblows
- Jan 23, 2007
- Central MN
- Jenkins, MN
They are both compression adjustable so X1. The front one has the dual spring set up on it. I'd like to get $580 shipped for the pair.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have set of xtx shocks from a 2011 all done up by Hygear. Center shock has dual rate spring setup on it.
SchelT
Ok, interested. Center shock have a piggyback reservoir and the correct length (13.25")?I have set of xtx shocks from a 2011 all done up by Hygear. Center shock has dual rate spring setup on it.
SchelT
I would only be interested in the front shock...PM me with a price and we'll work out the shipping details. How much use did you get before removing them?They are both compression adjustable so X1. The front one has the dual spring set up on it. I'd like to get $580 shipped for the pair.
