Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
- 2016 Polaris iqr 600
2013 nytro mtx 153 supercharged 180.
2012 yamaha nytro xtx (burned)
2009 polaris iqr 600(burned)
i want to put a 2 inch track on my nytro and 8 tooth wall bro drivers what kind of gearing do I have to do switching to 8 tooth drivers and is there any other mods I have to do to pull this off other than taking out the tunnel protectors?
TheKoning
i recently changed my track to the 1.75 bc. While doing it i put on a 19/39 top gear, changed drive axle bearing(clutch side), fixed limiter straps, and greased all the skid nipples. If i were you id do the same. The smaller top gear will make for better acceleration but lowers top end speed. which doesnt really matter since it'll still be like 150km/h and your off trail riding anyway.
Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
Do you still have 9 tooth drivers? And what happened to your limiter straps I broke one awhile back not sure why.
TheKoning
Ya i have the stock drivers still, i guess thats the 9 tooth ones. One of my limiter straps snapped so just replaced it.
mnman309
I have a set of Wahl 8t extroverts mounted on a shaft from an 08 i can sell you.
Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
The 08 shaft is not the same size as the 12 but thanks.
tdog1225
I did what u r wanting to do. I did the 2" track and went with 8 tooth drivers. I already had a clutch from Ulmer so he swapped me for a diff helix. He told me that by drooping a tooth I did not need to regear cause the smaller drivers do it automatically. In a week I will know how it does when I hit Albany, Wy
Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
Thanks I decided to just go with a 1.75 and keep the 9t drivers like thekoning did.
Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
What kind of clutch kit do you have or you still have the stock clutch ?i recently changed my track to the 1.75 bc. While doing it i put on a 19/39 top gear, changed drive axle bearing(clutch side), fixed limiter straps, and greased all the skid nipples. If i were you id do the same. The smaller top gear will make for better acceleration but lowers top end speed. which doesnt really matter since it'll still be like 150km/h and your off trail riding anyway.
TheKoning
Im stock, interested in a kit tho. never felt a need to get oneWhat kind of clutch kit do you have or you still have the stock clutch ?
NytroMisfit
- Feb 18, 2015
- Levant, Maine
- 2009 nytro xtx
is the shaft the same size between 08 and 09 xtx's?I have a set of Wahl 8t extroverts mounted on a shaft from an 08 i can sell you.
