WINDER1987
Hey guys i tried Contacting oft but never got a reply does the oft relocate give u a small rise in your handlebars? How much? Can you still get a riser along with the relocate how much can I go before having to extend?
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
That setup will rise the height of the bars. I'm running it with a 2 1/2" lake effects riser with no problems on the cables. Get a WRP seat and you will have a comfortable setup.
WINDER1987
ok thanks rooster ill def look into that setup. so guys seem to favor the arp seat over the skinz?
DSimps10
- Oct 10, 2014
- Oxford Michigan
- 14 Nytro XTX
It lifts the bars too, I'd say almost 2 inches. Here is mine with the relocate vs my friends without. He has a shorter windshield but it gives you an idea. I cant turn his key by reaching under the bars (easily) and thats the only way i start mine now.
Michigandir
- Nov 28, 2014
- Michigan
- 2013 Yamaha nytro rtx
OK I hear everyone talk about this,saying its a must have. i dont have an issue with my 2013 rtx steering. Is it just for taller guys or what? Why does everyone say its a must. Im 5'10'' and ride 95% trail. Please fill me in.
R00STER
- Mar 3, 2013
- Timmins, Ontario
I have never seen the skinz seat in person, but I'm sure it too is high quality. I know the wrp gives 2" rise but I'm not sure of the skinz seat. If you are keeping the stock seat I found that the relocate puts the bars at a nice height for sitting, for standup I guess it would be a preference thing if you need a riser too.
The relocate changes the steering to more of a push pull movement instead of having some up down motion in the steering. I was getting muscle cramps between my shoulderblades with the stock setup.OK I hear everyone talk about this,saying its a must have. i dont have an issue with my 2013 rtx steering. Is it just for taller guys or what? Why does everyone say its a must. Im 5'10'' and ride 95% trail. Please fill me in.
DSimps10
- Oct 10, 2014
- Oxford Michigan
- 14 Nytro XTX
I didn't think I needed the relocate either, the last two seasons I rode my friends rtx stock and loved it, when I bought my own this year I did it because everyone says its a must. Now I can't go back to the stock bar setup even for a few miles. I stand 99% of the time and am 5'10" the only downside to the risers is if you always sit the bars will block the gauges.
Michigandir
- Nov 28, 2014
- Michigan
Being a trail rider I'm sitting most of the time. Only stand when bumps are really bad. Or when I'm just sick of sitting. So is that who it's for? People who stand thru the deep stuff and ditch banging?
R00STER
- Mar 3, 2013
- Timmins, Ontario
Relocate is great for trail as well. Cuts down on the fatigue a lot!
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
The OFT changes the angle of the steering column. Two things occur; (1) the bars are about 2" higher and (2) they are easier to turn since the steering column is more vertical. Also instead of the bars sweeping more like a steering wheel its more of a push pull.
I noticed the height increase makes it way easier to turn and was comfortable - my shoulders told me so. I am 5'11"
I found no problem sitting or standing with the relocate. It improved both riding positions.
MS
MS
brs077
- Mar 8, 2005
- Cobleskill, NY
- 2013 Yamaha FX Nytro XTX 1.75
I am 6'5" and run the OFT w/ the Lake Effect pivot riser. I stand on trail or powder (though I also have the WRP seat). I love the setup. When rerouting the throttle cable as described there isn't any issue with stock cables. I ran a Schmidt Bros extended/braided brake line, but that was just for personal preference.
V10nr'
- Nov 4, 2009
- Canton Michigan
- 09 Nytro XTX, 11 Polaris Rush, 04 Sabercat, 99 Polaris trail.
Going OFT riser this summer. I also have the lake effect riser but it just is not tall enough when I stand. I'm 6ft and I still find myself slightly bent over.
brs077
- Mar 8, 2005
- Cobleskill, NY
With the relocate and the pivot riser I never feel like I am hunched over or leaned forward, and I never sit. I don't even know why I haven't just removed the seat yet, except for the hot exhaust pipe thing.
The best part of the combo is that the pivot allowed me to adjust my bars a bit more than a standard block riser would've.
V10nr'
- Nov 4, 2009
- Canton Michigan
That is what I wanted to hear.With the relocate and the pivot riser I never feel like I am hunched over or leaned forward, and I never sit. I don't even know why I haven't just removed the seat yet, except for the hot exhaust pipe thing.
WINDER1987
I'm just going to try the oft relocate and if it's not enough I will add a lake effect riser after.
