Nytro Rocket
2011 Nytro XTX
Changed track
Changed stock driver to Extros
Looking underneath the chain side had a much larger gap than the clutch side in the front (track to side of tunnel)..
Over and inch on chain side, and 1/4" or so on clutch side
It just looks wrong
I took it back apart and tightened it from the chain side again thinking it would shift and no change
What am I doing wrong?
It went really well changing the track, but the gaps are not even and it just seems wrong...
Changed track
It just looks wrong
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Are you sure you drivers in the right spot.
Nytro Rocket
These are stock drivers from an APEX
APEX 06
- Apr 30, 2009
- Sheboygan, WI
They still have to be measured to be on the right spot on the shaft
Nytro Rocket
I will pull them out and measure them. That's almost the only thing it can be the way I look at it.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
It sounds like your drivers are at the incorrect spots, are you using your nytro shaft with apex drivers?
Nytro Rocket
No, using the Apex shaft and drivers
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Is it the correct size and length? Didn't know they were interchangeable.....
