patamaran
- Aug 9, 2015
- Westree Ontario
- 2008 Fx Nytro
I was out riding in low snow getting to my trail, and the rider behind me told me he saw tons of sparks coming down from the tunnel in the middle of my track.
As far as I can. See there is not alot of steel up there. Aluminum doesn't really spark like that so has anyone experienced anything similar?
Where could it be coming from. I can't find wear marks that could be attributed to this anywhere....
Sent from my SM-G900F using Tapatalk
Grimm
Do you have a studded track?
patamaran
- Aug 9, 2015
- Westree Ontario
- 2008 Fx Nytro
Nope. 144" x 1.75 not studded. Tunnel protectors removed. The guy said it looked like someone buzzed a grinder In there there were so many sparks.
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
Sounds like a bearing. I would check the idlers and drive shaft bearings.
X 2 on the drive shaft bearing
Sent from my SM-G920V using Tapatalk
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Winter 2011: I followed a buddy riding his new Apex XTX at night and he was making sparks as you described. It was low snow and snirt. We looked and looked, but never found anything wrong. We finally decided it had to be sand coming in through the track windows and grinding the track clips, which made sparks. It wasn't a continuous shower of sparks, but more a spark here and there.
Sounds far out, but it's the only explanation. I have never seen that since.
I'd still look everything over as mentioned above.
ken0la
Nice night time mod brother but LEDs are the way to go! Lol
If bearing was throwing sparks it only makes sense that it would be making a loud grinding noise, did you notice any?
patamaran
- Aug 9, 2015
- Westree Ontario
- 2008 Fx Nytro
No I didn't notice any noise or vibration. And the sparks stopped soon after. They were coming from the back nothing near the driveshaft or the front of the sled.
Grimm
Maybe check to see if the screws that hold your sliders in place are still there.
patamaran
- Aug 9, 2015
- Westree Ontario
- 2008 Fx Nytro
Good idea.... Lol
Keith1962
- Mar 26, 2015
- Camillus, NY
Check your track clips as well. I have seen idlers bearings so worn that the wheels were just loose on the rear axle, and no one noticed vibration or anything... Seems impossible but true.
gmfamily2008
Broken header? Might see something like that blowing thru the cracks . Just a thought
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Most likely the track clips and rocks or sand coming into the track. Low snow with a big track like that.
patamaran
- Aug 9, 2015
- Westree Ontario
- 2008 Fx Nytro
More snow this weekend and no issues rider behind me I asked him to take a look he said he didn't see a thing. Thanks for the input.
sprintcat
