drunkenrich
Anyone use the rsi hand warmers? Easy to splice in? Also, any reviews on this? http://www.firstplaceparts.com/rsi-snowmobile-handlebar-gel-wrap-grips.html
johnelway
me and go for it! great fix for the handwarmer. get the rsi grip too. really confortable and less slippy.
drunkenrich
Easy to install both?
johnelway
if you have already splice a cable. yes.
keep the connector from your old ones ans splice them with the rsi
Super easy. And the ODI grips are super comfy. Just don't do what I did and put alum bars on. Kinda defeats the purpose.
drunkenrich
Why, is the aluminum too cold?
It doesn't transfer or hold the heat as well as steal.Why, is the aluminum too cold?
Tyloooor
I did mine last summer- they work super good with a yamaheater
I also spray foamed my bars
drunkenrich
What do you mean spray foamed the bars? The insides? Keeps you warmer?
12meter joe
What's the issues with the hand warmers? I have a 12' and they cook my hands. Is it a certain year they sucked?
Nytro77
Not sure about the 12's maybe they corrected them but my 10 I lost factory left handle bar twice and when they did work they not very hot at all. Then I finely installed RSI warmers solved the problem and work great and easy to install.
Nytro77
Yup go to your local hardware store and pick up a can of spray foam the same stuff you spray around your windows to keep the cooled draft out. Spray inside both sides of the bar " not to much " it comes fast and expands once it sets up trim the end. This will stop the heat from your grip to be loss through the bar.
