Rtx rear limiter strap.
fxnytrortxkid
Age
42
Rensselaer, ny
09 nytro rtx
Just curious if anyone playing with this has some info. I haven't one anything with it yet as I wasn't totally sure what to change. Longer less coupling more transfer, shorter more coupling less transfer?
Im pretty sure if you tighten the strap it gives you less ski lift but your hook up is not as as good. And the opposite if you loosen it.
That's where I am "assuming" also, but after a web search I've only found "it controls coupling" as sn answer lol
when you pull in the limiter strap (shorten) you raise the fron of the skid that in turn puts more weight on the skis and will help with cornering but reduce the ski lift under power and cause more track spin as less weight is transfered to the track and vise versa for the reverse.
