BigDogrx1
Guys I am thing about putting under tunnel exhaust on my sled and really modify rear end.
Here's my concerns for opinions.
1. Want not much louder than stock.
2. Who or what kinda muffler 3x14" w/turn down?
3. Anyone have like glass pack with double front pipe.
So you can just slide it on stock front two pipes?
4. If it caused you any problems tell me please.
5. Do you have to rejet carbs.
*****I have clutch work & 22 tooth gear.
Thanks for any help, Larry
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
Larry did this on my vector. There is a post "Magnaflow muffer on vector" the sound was perfect but it got lounder removed it. It does create more heat, if you do not have
rear heat exchanger it will over heat.
I will look up the post for you. Was fun project
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
Larry it is on page 47 RS VECTOR SECTION UNDER SOUND CLIP list to sound clip then click on next for more
BigDogrx1
Hey Tom, the rx has rear coolant flow, what did you do with yours when removed (still have)?Larry it is on page 47 RS VECTOR SECTION UNDER SOUND CLIP list to sound clip then click on next for more
I only use phone for internet so listening won't work, thanks
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
Yes I still have it we could meet if want to install it
BigDogrx1
Ok guys been reading for 3 days on tunnel dump, and Iam leaning towards a glass pack & baffle.
Seems like tunnel ice should not be a killer since mines a 121" and trail sled, not much off trail ?
BUT can't find anyone tell how pack SOUND changes baffle insert?
Any response would be helpfully.
- 32K
