4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
It's been 8'ish years since I've had to shim my skis. I used 1/8" x 1" aluminum cut to the width of the ski rubber. I then drilled and c'sunk a hole in the shim and screwed it to the rubber.
So is there a better method or how do you guys do it? The skis on my new 14 Vec LTX need to be shimmed.
depends on how much shim I need. usually 1/8 aluminum is enough but I have had to use a chunk of transport mud flap or worn out slider plastic with the sides cut off.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
AZEK or simboard. Easy to cut on miterbox saw.
TRUE BLUE SINCE 1980
I used flat aluminum also on my 10' vector also. Used good two sided tape to hold the shim to ski. I think it is 3m with the red pull off backer. The tape really bites into that waffle surface on the ski. F.Y.I .... I think it helps the Vector.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I've always used aluminum plate
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Used 1/4" x 1" alum bar. Attached them to the skis with screws rather than to the ski rubbers.
First time I can recall being able to attach them to the ski. So why am I thinking it was a bad idea?
mooseflyer
I'd guess HDPE or UHMW plastic would be ideal (i.e. kitchen cutting board material). Easily custom machined with any household tool. I haven't done it though....
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
We have sheets of Lexan clear plastic at work. I use that, works good and doesn't corrode.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
We have used toilet shims. Pretty much HDP cut to about the right size.
engineman
- Feb 19, 2013
- Between Hastings & Redwing MN
- 2009 Apex LTX, 2010 Vector LTX GT, 1996 Indy 500 SKS
I have used the plastic applicators for body filler in the past. Tapered which seems to work well.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I like the idea of using of tough plastics for sure.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Old drive belt with the nubs cut off!
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I guess I'm not lucky enough for my drive belts to get old. They have grenaded themselves when they decided their time was up.
Yamadog
in a pinch i have run sheet metal screws into the rubbers letting the heads be the shim usually 4 of them across the rubbers
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Perfect time to use them, only need pieces the width of the ski rubber!I guess I'm not lucky enough for my drive belts to get old. They have grenaded themselves when they decided their time was up.
- 32K
