rocco17
anyone stud a backcountry 1.75 IM NEW TO THIS, ASKING QUESTIONS I HAVE A 2013 XTX AND WANT SOME OPINIONS OR WHAT YOU HAVE DONE STUD WISE THANKS ROCCO
rocco17
im new to the nytro but did i ask a dumb question?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I don't even think anyone makes a stud long enough for a 1.75" lug track .... but I could be wrong.
NS FX NYTRO
I had a 1.75" sno x track on my 07 mxz 440x and like all other snow x sleds they are studded with double backers and tall nuts. So they do make them long enough, just not sure on the nytro if it's doable
rocco17
i have the studs with tall nuts and all but i see that to put on this track you have to take out the tunnel protectors witch makes me think you cant use them thanks for responding
gmfamily2008
will only be able to do this by going with a smaller driver , with stock drivers a 1.450 stud just makes it ,anything longer you`ll tear out your heat exchanger
rocco17
kind of what i thought by reading other posts and reading between the lines thank you
stubb111
just curious but, why would you be able to run a 1.75 track without rubbing and only a 1.450 stud before rubbing???
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
My guess is with heat exchanger protectors removed you gain the extra clearance needed, but then you can't run a stud.
stubb111
the xtx 1.75 comes with heat exchanger protectors on it???
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
May be running a smaller driver.
