APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I'm starting from having the gas tank, seat, head light pod and body parts off. FIRST STEP remove the wiring hardness out of the way. Then remove the two screws that hold on the white cap.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
APEX 06
- Apr 30, 2009
- Sheboygan, WI
APEX 06
- Apr 30, 2009
- Sheboygan, WI
APEX 06
- Apr 30, 2009
- Sheboygan, WI
APEX 06
- Apr 30, 2009
- Sheboygan, WI
APEX 06
- Apr 30, 2009
- Sheboygan, WI
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Step 9 grease the bushing(use a low temp grease), grease the shaft. Then push the back half of the new bushing and backing plate in by pushing the bars toward the ski's. Then put the metal sleeve's back in the bushing after they are cleaned.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Step 11 put the front plate on with the wire holder, then the plate with the tabs that hold the nuts
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Step 12 PLEASE remember to bend these tabs back down and I use loctite for the nuts.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Step 13 the lower upper bushing's nuts are behind the wires and the nuts have black rubber caps on them to protect the wires. You will have to move the wires out of the way to get to the nuts. After that everything is the same as the one before. Just everything is toward the gas tank.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Step 14 push the black cap back on the bolts after you have it bolted back in. Put the wires back/zip tie them in place.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Step 15 ok this one sucks you have to remove the air box and undo the oil tank so you can move the shaft to get the back half bushing out. When finish with this one go back and bolt the plate back on that you took off in step 14. That's it when doing this I would check your donut and change your plugs(if needed). Total cost for the stock bushings was 22.00 bucks from Sheboygan Yamaha.
- 46K
- 146K
