tors issue
Re: tors bypass
snowbiscuit said:
The bypass is just below the light pod inside the clamshell looking cover
Are they bullet connectors like the older yammies because I can't find it
Re: tors bypass
Not true bullet per say, but white & black single wires with plastic snap together "sorta but not really bullet style" connectors.
I should clarify mine is an 08 if that makes a difference and what I found was a blk/blue single wire with black connector and a blk/ yellow single wire with white connector would that be the tors wires? They are in the rubber pod
That's them.
Hook the ones coming from the clutch side together. Leave the other ones loose.
