stomper
During the ton of maintenance work on my sled I have noticed that some of my track clips are missing and some are broken. I want to replace them with new. Whats the easiest way to do this.
Buy the clips and track clip tool from any after market shop and crimp new ones back on.
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
do not buy long handle tool it breaks first time used, it comes with a dis-claimer but the screw down clamp that matches the clips
I have done this big job. Can be done without removing skid
stomper
What's the easiest way to remove damaged clips
wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
http://www.snowgoer.com/top-stories/how-to-replace-snowmobile-track-clips/1113/
You can also fab a tool with a long handle and two "teeth" on the end. The teeth are offset a little and jam down into the gap. Then you pry them off. This requires removing the track first.
https://www.youtube.com/watch?v=ZUViPOrB36U
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
I used small side grinder
Yooper_Bob
I use the Sno-Stuff track clip tool: http://www.tracksusa.com/SNO-STUFF-TRACK-CLIP-INSTALLATION-TOOL-detail.htm?productId=18118330
Works great, and can easily install clips with the track still on the sled.
