Indy
98 vmaxx etc deluxe. Ya, I know this is the 4 stroke side, however I dont have much luck on the 2 smoke side.
1. The steering is very sloppy, loose. So I know it is in the shaft, underside of motor, what are the parts needed? does the engine need pulled?
2. Grips, I've had to re-rivet a few times. The switch turns way too loose. Now they've quit working.
do I need to replace all? OEM or aftermarket make a difference? How do you remove the old grips and replace (tips)
I plan on attending the Novi show so I can purchase the parts (aftermarket) there if necessary.
Phazer2Viper
- Apr 14, 2014
- Slinger, WI/ Three Lakes, WI
- 2015 Viper LTX-DX 15,000 miles and counting!
2008 Phazer GT 128" track 10,444 miles (sold)
2008 Nytro RTX 136" 3800 miles (sold)
2000 Phazer 6500 Miles (Sold)
1990 Phazer II 10,000 miles (sold)
I can help you out with the grips. You should just stick with the OEM grips. Some aftermarket grips dont work on yamahas. OEM 2stroke grips worked great for me.
Yamadog
The steering linkage should be accessable by removing the expansion pipe. Its been years since I sold mine but there might be a linkage behind the motor also that may be the culprit. Mine had 16000 miles on it and was still as tight as the day it was built.
Yamadog
Here is the look up schematic
http://www.yamahamotorsports.com/pa...(1998_SNOWMOBILE)/STEERING_(VX700XTCDB_-_1998)
Yamadog
Sorry that link fails just go to Yamaha sight and go to snowmobile parts
- 46K
