Matthew457
Skid plate, you need 4 riv-nuts and bolts with washers for the bottom and 2- 1" long bolts with washers and nyloc nuts for the nose.
Matthew457
Thanks! Hopefully those are easy to findSkid plate, you need 4 riv-nuts and bolts with washers for the bottom and 2- 1" long bolts with washers and nyloc nuts for the nose.
You should be able to contact Yamaha to get a new mount kit. I know I have bought them from Port Yamaha before.
Matthew457
They aren't just normal nuts and bolts you can get in stores?You should be able to contact Yamaha to get a new mount kit. I know I have bought them from Port Yamaha before.
I know at Menards you can get threaded inserts and the tool to install them for the bottom and then just get some SS hardware.. 1/4-20
Matthew457
They always gotta make it so stupid to install things lolI know at Menards you can get threaded inserts and the tool to install them for the bottom and then just get some SS hardware.. 1/4-20
Matthew457
How do you install riv nuts? Just using a rivet gun?I know at Menards you can get threaded inserts and the tool to install them for the bottom and then just get some SS hardware.. 1/4-20
Its a threaded insert tool.. Riv-Nut is a type of crimped insert.
Matthew457
More money that has to be spent haha, I think I might abort this skid plate idea...Its a threaded insert tool.. Riv-Nut is a type of crimped insert.
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
It wont take much. I have the same skid plate on my sled. I go rid of the Riv-nuts because they suck. I put regular inch long bolts and tighten a nut on there so they wouldn't move. Then I pushed the skid plat up and put another nut and washer on it and have never had a problem doing it that way. You will want ta skid plate on a nytro as that is one of the biggest down falls to the nytro. If you hit one bumper wrong and push something up into your belly plate you could dent and put a hole in your filter and your done for if you don't notice it leaking.
Matthew457
Alright, I'll take a look at it this weekendIt wont take much. I have the same skid plate on my sled. I go rid of the Riv-nuts because they suck. I put regular inch long bolts and tighten a nut on there so they wouldn't move. Then I pushed the skid plat up and put another nut and washer on it and have never had a problem doing it that way. You will want ta skid plate on a nytro as that is one of the biggest down falls to the nytro. If you hit one bumper wrong and push something up into your belly plate you could dent and put a hole in your filter and your done for if you don't notice it leaking.
Ray Reed
Buy Moutain Tech skid plate. Very good quality and easy to install. Hit a stump with the plastic and you will wish you had the aluminum Moutain Tech!
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
Go to napa and you can buy the same type of nut that mountain tech uses on his aluminum skid plate. They are called a U-nut 6mm x 1.25 pitch, they slide over the hole where the riv nut would go and there is a spring like hook that holds the nut in place from falling off when you take the bolts out. Then go to fastenal or what ever your local bolt place is that carries metric hardware and pick up some 6mm Phillips pan head bolts or socket head bolts which ever you prefer and 4 fender washers to fit the bolts. Put the bolts in with a small dab of blue loc-tite. I think you can also get a skid plate install kit from Yamaha with the riv nuts and the tool that crushes then down, I use their bolts because they are coated to not rust .
I have found over the years that those riv thread inserts have there place and they have to be installed correctly . If they ever come loose then they will just spin in the hole and that is usually caused by the steel bolt corroding in the aluminum insert and seizing in place in the threads causing you to apply more force until the insert strips . It's fine if you can get a vice grip on the insert , you can get them loose but in the nytro's case they are hidden out of the way and you can not get to them.
herndonp
Yes go with the u-nuts. That's what I did as the riv nuts got loose from vibration and I had to drill them out. Napa sells them in small packs I used 1/4-20 U-Nuts and SS 1/4 20 hex heads.
Pete
Pete
