Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F, '79 Trail Fire
The Vector motor and Nytro are the same except for the stator. The Vector stator puts out more amps which drags the overall HP output down as compared to the Nytro. The stator on a Nytro is much smaller and puts out less amps which is why a Nytro has more ponies under the hood. It also explains why the hand grip heaters dont work well to.
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
The cams on the Nytro and Vipers are different part numbers than the Vector and Venture. The stators are different but I think the cams are the big factor for the HP difference. Other than that they are pretty similar
This is the correct reason it's not the stater it's the cam valves and valve springs.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Stator does not draw that much hp! 300 amp alternator on your truck will but not the stator on your sled.
ydog
- Feb 4, 2015
- Berrien Springs, MI.
- 2014 Apex XTX
2012 Vector
2009 Nytro
The Nytro motor is definitely not the same as the Vector motor, sure their both 3 cylinders but there not the same hp out put and do have differences between them.
MidwestMike
- Sep 14, 2012
- Oak Lawn, IL Ride in SW Michigan
- Vector
I know the cams and springs are different, but isn't it the EFI mapping that makes the two motors feel so different?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I'm wondering if they didn't just standardize all the 1049's by putting the nytro cams/springs in the Vector engine so all the the long blocks are identical now for 2016. Makes sense as a money saving move and not bad for the consumer also.
swampcat
Just read about this in the latest issue of SnowTech. Was going to ask if this involved the 2016 Viper, but sounds like it does NOT .
Could Yamaha be getting ready for a Factory Built Turbo??
http://www.supertraxmag.com/article.asp?nid=2929
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
That would not make me happy as I am all about mileage & range on the Vector.I'm wondering if they didn't just standardize all the 1049's by putting the nytro cams/springs in the Vector engine so all the the long blocks are identical now for 2016. Makes sense as a money saving move and not bad for the consumer also.
sideshowBob
That would be my bet as Arctic Cat needs Yamaha, as their engine supplier, to supply a turbo to replace the Suzuki engine.
yooper1
I agree, it would be nice to have a factory built turbo with all the “prewiring” and gages. That I might buy in the future.
RobWarrior
There's not much of a difference in mileage between the 2, my Nytro and buddies 2010 Vector are within pennies at the pump, my carbed 07 actually kills both of them in mileage.That would not make me happy as I am all about mileage & range on the Vector.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
My MCX 290 Turbo Apex gets better mileage than my stock Apex as long as I am not on the bar with the turbo all the time.
I had a 700, 600 & 500 2 stroke V Maxes all at the same time. Every fill up the 700 took the least fuel & that was mine being driven harder than my wifes or sons.
superfan75
My old SRX blew everybody's minds when we got gas. I would use less gas than the Polaris 550 fan that was supposed to be so great on gas. Just because a sled has good power doesn't mean it will be bad on gas.
