jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
Hey guys, just pulled my sled apart for the first oil change and after I took the skid plate off I found a nut laying on the floor. 20 minutes later I pulled the sled aside so I could have more room to work and found a screw that fit the above nut... are they important? Do they look familiar?
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Looks like the Philips bolt that comes with a new battery. Not sure about the nut...
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
It may be the fastener that holds the reverse beeper to the frame. Its just above the disc brake. Take a look.
MS
MS
jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
Thanks.
NS FX NYTRO
That's a possibility, but I can't confirm, as my reverse beeper was missing the bolt/nut combo when I first took sled apart! Lol. I used a heavy zip tie, been there for 2 seasons.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Without a doubt, that's the back up alarm bolt. It's been a common problem so you're not the first to ask this question.
