stormin norman
- Dec 11, 2007
- Southern, MN
- 2014 Yamaha Viper LTX LE
2000 Yamaha SRX 700
1999 Yamaha V max 500
1992 Yamaha V max 4
1984 Yamaha Phazer
Does anyone here have a pair of the Yamaha Flotex Bibs? I just bought these and they have a foil looking inner liner and are very, very warm but the problem is they don't breath at all and boy do you sweat. On a warmer day it is uncomfortable to wear as they are to warm, you guys know what I mean-my boys need air!
Any one else wearing these?
sgauthier
I don't have those but are you layering?
stormin norman
- Dec 11, 2007
- Southern, MN
2000 Yamaha SRX 700
1992 Yamaha V max 4
1984 Yamaha Phazer
No they are not layering.
sgauthier
You should try and get yourself a pair of base pants to wear against your skin then a midlayer over top of those. This helps wick the sweat and keep you cool. Maybe that would help
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
He's right, those bibs alone are fairly warm. All you need is a thin wicking base layer, like silks or thin underarmor or its equivalent, they are not supposed to insulate, just wick and keep your skin dry. Then a medium weight layer, like polartec 100 or Klim mid-level. I use the Marines ECWCS level 1 and 2 for this exact purpose. Then the bibs. NO COTTON!!!! I.e. no jeans or those crappy waffle long johns. Cotton is crap and it holds moisture against your skin making you cold (water takes 20 times the amount of energy to keep it warm than air, hence zapping energy and heat from you to keep it warm in the clothes right next to your skin). If your perspiring then your overdressed, you need to shed some insulation. If you have to, run with just the wicking layers.
stormin norman
- Dec 11, 2007
- Southern, MN
2000 Yamaha SRX 700
1992 Yamaha V max 4
1984 Yamaha Phazer
Tonight went for a ride and wore just sweats and much, much better. Thanks for the input.
