82SRX500
- Oct 6, 2005
- Hampshire, IL Near Chicago
- www.toizrit.com
That's interesting. I was just at my dealer this morning. He told me there was still no bulletin on studding. He called Hauck Powersports in WI, and was told there have been no issues so long as you run 1.325 studs, do not use longer studs. vHe also told me they have a protector for the EXUP valve for $50.00. So I ordered one.
82SRX500
- Oct 6, 2005
- www.toizrit.com
slimjim2525 said:That's interesting. I was just at my dealer this morning. He told me there was still no bulletin on studding. He called Hauck Powersports in WI, and was told there have been no issues so long as you run 1.325 studs, do not use longer studs. vHe also told me they have a protector for the EXUP valve for $50.00. So I ordered one.
If you could get the Part # for the Exup valve protector and post it here that would be helpful.
Jon
blustar
- Mar 11, 2009
- Manitoba
- members.shaw.ca
- Yamaha Apex and RS Vector
Will that EXup valve protector fit on a basic 2008 Apex?
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
2008 APEX DOESN'T HAVE ONE !
snowman 700
- Oct 10, 2005
- Mid-Michigan
- 2011 Apex SE
2012 Vector (wifes)
Thanks for posting....Looks like we will need to add a shim. It looks like the memo says between the tunnel and the bracket. I think it would be best to put it between the u shape mounts for the protectors. Has anyone tried this? What size did you cut the shim? and how to attach.
Dave
Dave
Banks93
I know my dealer made something and sent pictures to Yamaha.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
what a joke how do you sell a high performance sled which most eveyone will stud and act like nobody should stud...always covering their close offs...
Preacher
do all the manufacturers cover themselves in this way or is this unique to Yamaha?
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
That does not appear to me like a valid bulletin Yamaha would put out. To my knowledge bulletins are a controlled document and should have a number assigned.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You are correct, it is not an actual "bulletin" but rather a "Parts & Service Message" to all Yamaha USA dealers.
82SRX500
- Oct 6, 2005
- www.toizrit.com
BADSLED said:That does not appear to me like a valid bulletin Yamaha would put out. To my knowledge bulletins are a controlled document and should have a number assigned.
Got the bulletin directly from my Yamaha dealer. Contact your dealer and ask them for a copy and you should get the same one.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Srxspec said:You are correct, it is not an actual "bulletin" but rather a "Parts & Service Message" to all Yamaha USA dealers.
so what's the difference?
snowman 700
- Oct 10, 2005
- Mid-Michigan
- 2011 Apex SE
2012 Vector (wifes)
Arctic Cat puts Studs and Templates in the Accessories Cat-a-log.
Preacher said:do all the manufacturers cover themselves in this way or is this unique to Yamaha?
LJ 452
Huh, that's weird my Phazer MTX has an under tunnel exhaust but no protectors. I believe all the Phazers came without them.
Basically they F-'d up and didn't allow room for studs. How that happens in this day and age is beyond me. Oh the headlines, I can see it already, the others could have a field day with this. Whether you run them or not you can't argue this is a major oversight. If that's the case is it safe to assume you won't be able to run a 1.375 or 1.5" track either?
- 6K
