Yama-Crazy
- Jan 10, 2005
- S/E Michigan
- 2014 Yamaha Viper rtx
Has anyone already installed an in-line gas filter?
yamahajunkie
put 2 extra on my powerstroke. filters down to 1micro. no problems with injectors yet!
i think it would be more effective on the 06 fi sleds.
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
I dont know but I heard the jets on the 4stroke carbs are much smaller than two strokes so if thats true it seems like it would be a good idea for all the 4stroking Yammis.yamahajunkie said:put 2 extra on my powerstroke. filters down to 1micro. no problems with injectors yet!i think it would be more effective on the 06 fi sleds.
KbxSrx
I always used 2 on my rx1. I cant see a down side
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
Did you get your right at the Yammi dealer? Do you have any part #'s Or can I just find one at an auto store?KbxSrx said:I always used 2 on my rx1. I cant see a down side
03griz
Are there not filters in the tank?
hey citizens,
i installed inline filters after getting poor fuel from delivering yami dealer,
pilot jets were PLUGGED. i see no down side , these are from yamaha, they are the ones used on the R1 motorcycle. the intank paper filters don't catch the small stuff. these cost about $10.00 each that's cheap insurance and keeps you from having to pull carbs for cleaning.
rfc
skip
ps
i wraped them with foam insulation to protect from high heat comming from exhaust header.
rfc
skip
ps
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
I run 10 micron filters on my Yamaha outboards. It helps to keep debris out, but will not help with storage. You might still have problems with varnishing from fuel. Seems the ethynol makes the fuel go bad faster. I know they have had problems with outboards, Yamaha, with ethynol and paper filters. Here in the east lots of work for the marinas.
sorry friends ,
i must be click happy on the submit button, only wanted it posted once.
rfc
skip
rfc
skip
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
those are not filters in the tank, there are screens tho in the tank to keep large objects out of the fuel system...they are not considered a filter at all.03griz said:Are there not filters in the tank?
Bill-winnipesaukee
- Feb 21, 2018
- Alton, nh
- 08 Yamaha rs venture 2up
05 Yamaha rs rage 1up
Just worked on replacing the screens. Here is a tool at home depot that makes it easy... https://www.homedepot.com/p/Husky-24-in-Lighted-Mechanical-Pickup-Tool-70396H/206264355
Thanks for pointing out that these aren't really filters, i can see wanting to add the in lines
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Well my 05 has filters in the tank, not screens filters! Adding a second couple filters to the lines won't hurt!
jameshofo
I did it on my wifes RX1, that sled ran great for 2 years and I didn't even clean the carbs after the summer (I did put in fuel stabilizer before storage). I recently did have a problem with it because one of the fuel filters had developed a hole . I put mine right next to the steering post on top of the engine, if you do the same I'd recommend buying the metal filter, or just changing it out before the start of each season. I ended up using a FRAM filter you can pick-up at any Wal-Mart, but the fitting on that one is a little big to squeeze on the fuel lines.
Its also really nice to be able to see the fuel flow on both fuel pumps.
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Holley used to make alluminum filters with a stone like filter inside. Used to buy them in motorcycle shops!
