Phantom
- Apr 2, 2004
Ya gotta love it!
Any idea how many hours or miles on that engine? Was it broke in?
It may have been a little tight too!
Tfin
Hmmmmm............
LazyBastard
Well I measured my RX to use 2/3 of a 2-stroke 600cc carb'd vmax twin, so using half the gas of an injected engine is pretty amazing.
snowmotion
- Nov 5, 2003
- BANFF ALBERTA WHISTLER BC
- www.snowmotion.com
I Would Like to see those Numbers Against the RX1
I Would Like to see those Numbers Against the RX1 as a curiosity
But i Also wonder About real world milage on fuel economy.
I often find My range on my Rx1 is about the same as a rev 800
running similar miles same day same place We DONT put around
so we do burn gas but I Know I Pay Less at the Pump the RX1 fuel tank is just smaller but my Range of Use is Similar to my friends 800 revs or a only a little better. But They Do Ride Harder Than me I Just Carry More Stuff Like 80 LBS or more of Stuff which us equalizes nicely.
That said the Dyno of a Turbo vector will likely be Equally impressive
I see a huge range of usable hook up power stock but why no data at very LOW rpm?
welterracer
Anyone who ordered a new vector is LUCKY!! In snowtech mag.. the vector has more HP and TQ Than any other 600cc machine!
Flipper
- Oct 31, 2003
- Ottawa, ON
- 2018 SideWinder LTX LE 50th
- Ottawa
The suspense is killing me. Can't wait until mine shows up.
Then the wait for snow will be real long....
TurboVector
It has to be wrong to be wishing for snow this hard in August.
Rocket
I will back those numbers up. Everything I have seen so far run right in line with these numbers, except I am about 29.65hg barometer and 67 degrees farenheit. 117.9 chp at 8600rpms
06vectorgt
Hello Mr. Sled
If this is a "Sticky" why do I get the below response, I would like to see the numbers if you could dig them up again.
Keep up the great work and thank you in advance.
The selected Attachment does not exist anymore
404 File Not Found: The File files/rs_vector_hp_numbers.jpg does not exist.
Looks like some files are missing...I will check and see if they are still on the old server.
06vectorgt
Thanks, I have an 06 Vector GT on order and I would like to see the numbers. If it is to much of a problem I'm sure I will live without them.
Thanks again!
Lou
Thanks again!
Lou
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Ask and you shall receive!
Dynoray
- Oct 19, 2005
- NS, Canada
- www.fundypowersports.com
Hey SRX, that's exactly what we got on a stk RS 118.2HP.
This motor responds very nicely to a little porting, compression and cam timing, 136HP and almost 90ft/lbs of torque.
Makes a nice little sled in 500ft.
Thanks,
Ray
Thanks,
Ray
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
- 2014 Yamaha Viper rtx
Anyone know if there is someone in the Michigan area that could do some porting and tuning , timing near me?
