**APEXGT**
Anyone try one of these???
http://cgi.ebay.ca/PERFORMANCE-CHIP-YAM ... 286.c0.m14
welterracer
Its a scam..
Im sure there is alot of guys that will buy that hoping to get more HP but end up getting a BOG..
HONDAFIXER
It must be true I read it here:
Dyno-BOOST is a fully adjustable, programmed performance control unit designed for all snowmobiles controlled by ECU, simply wires inline with the factory harness of the IAT (Intake Air Temperature) sensor.
You will receive crisp acceleration, much more horsepower and torque, with perfect and smooth sliding, with surprisingly increased throttle response. Installation is easy, no - special tools or expertise required. Gain +15-35 additional HP, and extremely dynamic acceleration by up to 30 % in contrast to factory engine performance. It works in conjunction with stock ECU and will not affect engine reliability or endurance. Original ECU program is in process, but the signal of Dyno-BOOST is overwriting it in each microsecond resulting richer air/fuel ratio, accordingly delivering peak horsepower, torque and acceleration.
welterracer
Nope not true..
THere is nothing you can plug into your sled that is going to give you 15-35hp PERIOD.. unless you got nitros..
THey have been scaming people on ebay with those gadgets for years..
Yamahammer485
LOL!!
Give me a break, as if these people eve try to sell this crap. Throw in some fancy words which have absolutely no application to this little electronic device and people might think that it is actually something.
For instance, if it suggests that much power, how does it suggest it make that power, LMAO!! Read it harder and you will see, all they do is state that it works good.
Attak-Firecat
Awesome! You mean all I have to do is turn a screw for more power? Wow! Everyone should have a "more power" dial on their sled.
This is hilarious!
This is hilarious!
MR.HAPPY
- Sep 30, 2003
- GREAT NORTH OF... ILLINOIS?
- YAMAHA
Its true....... I gained 100 hp when I put 4 of them on my LTX!
BR
BR
